Having done an engine swap, the ECU was defeated to enable the TT set up to run in my Golf. Is it possible to reverse the Immo defeat? I assume you'd need the SKC code and go from there?
Just to clarify the ignition key and clocks are the cars originals, the ECU is new and defeated, is it possible to reverse the Immo defeat and code everything back to the ignition key?
The ECU will need the defeat removed, then you'll have to code the ECU to the cluster like normal, you'll need the SKC for both the cluster and the ECU to do that.
The only issue you might have, is if your Golf is IMMO2 and the ECU is IMMO3.
