Results 1 to 7 of 7
    s3 addict's Avatar
    Sep 2011
    Swadlincote, United Kingdom
    Question Boost Controllers
    Any thoughts on boost controllers? Thinking of bypassing the N75. Good idea?
    Audi S3 210bhp (Remapped to 260+), Black, Forge DV, Forge Boost hoses, Forge PCV hoses, K+N Induction Kit with Stainless Steel Heat shield, Powerflex front wishbone and anti-roll bar bushes, EBC grooved front and rear discs and Red stuff Pads, N249 Deleted
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    To stop a spike? if not why?
    S3 Paul's Avatar
    Oct 2006
    2,764
    Im pretty sure massively bad idea without alot of mapping work. otherwise the ecu requested boost will never stay with in the limits of the map
    Noggy Blue 2001 S3
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    no point really.
    a MBC to cap a spike maybe, but otherwise no real point
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    VAG ecu has torque control to control the turbo spool on part throttle... this makes the car feel drivable and smooth... fitting an EBC or MBC will get rid of this and will not only make the car fairly awkward to drive (unless on WOT all the time) if the mapping isn't setup for using an EBC/MBC then it will probably end up in limp mode most of the time..
    One other myth that should be expelled while we are on about it... don't think you can add an EBC/MBC to get more boost either... its the same issue as above... the ECU will probably have a spazz or worse if the fuelling hasn't been set right the engine could melt..
    EBC/MBC have a place but generally not until you are running bigger turbos/power or using an MBC to counter big boost spikes from crap maps or tired actuators..
    <tuffty/>
    RIP S3dave
    May 2004
    nr Glos
    7,161
    on std unmapped car - agreed
    on mapped car, depends on where/if they moved the deviation limits.. if ebc wont cause a deviation code.
    ebc on lupo (eboost street) - works well, superb boost control, 2 x settings..
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    s3 addict's Avatar
    Sep 2011
    Thanks for the advice, think I'll leave it then. Didn't realise it could upset the drive so much.
  1. Boost Control
    By rraghvani in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th June 2005, 13:39
  2. Anyone fancy a boost controller?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th January 2005, 22:17
  3. turbo timer and boost controller
    By imported_BigChris in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th September 2004, 21:08
  4. Boost Controler
    By Markey in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th May 2004, 14:48
  5. chipping in general-varable boost controller
    By tvr1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th July 2003, 10:20
