Badger5Sky Insurance
    Sep 2011
    doncaster
    98
    re: internal control module error
    just checked my fault codes through vagcom and got these fault codes
    awd
    00526- brake light switch implausible signal
    65535- internal control module error
    are these connected in any way? and could the brake light switch be causing the ecu memory error?
    Sep 2011
    doncaster
    98
    just looked under the rear n/s next to the driveshaft and there is no earth cable for the haldex system. anyone with a diagram or pictures to show me where to rewire it from and to?
    no cable hanging down anywhere neither
  1. 65535 internal control module memory error
    By SDO in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th August 2010, 20:13
  2. P1604 Internal control module driver error
    By hibee1 in forum TT/TT-S/TT-RS Forum
    Last Post: 31st July 2010, 19:00
  3. Error Code: 16985 - Internal Control Module: Memory Check Sum Error
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th March 2010, 11:34
  4. Replies: 8
    Last Post: 7th October 2006, 10:15
  5. removing climate control module
    By DrX in forum A4/S4 forum(B5 Chassis)
    Last Post: 19th September 2003, 08:30
