Chris NottMonster Motorsport
Results 1 to 7 of 7
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    782
    Help with Engine management light with picture
    Would this being broken cause my engine management light to come on I know its a long shot but it looks like there is a sensor it is to be attached to
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Possibly not but will cause your MOT to fail potentially... that a sensor for the Xenon leveller system..
    Scan the car for faults codes... that will tell you why its on rather than guess...
    <tuffty/>
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    782
    <tuffty/>
    Well the last time I had the car scanned when the light first came on it came up with speed signal sensor and was able to wipe it the after driving the light came on with the same code!
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,018
    Chances are its the same fault then... clearing the code isn't really a fix especially if its an intermittant fault... when you scan next post up the full code and description as each component has a couple of fault codes it can use...
    <tuffty/>
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    782
    I'll try and get my car scanned and i'll post the results on here the car doesn't feel any different but just seeing the light on is a bit annoying!
    sideways steve's Avatar
    Dec 2011
    Paisley, Scotland
    344
    Are all of your tyres the same size and all at the correct pressure ? If one is soft compared to the others the car can throw a speed sensor error. I have seen it many times before believe it or not !
    MURRAYS444's Avatar
    Aug 2009
    Edinburgh
    782
    Quote Originally Posted by sideways steve View Post
    Alright mate its still the same from us fitting the other clocks lol seen the broken link and thought that could be the cause all the tyres are the same pressure and I changed the front nearside one that did have a slow puncture in it after you noticed it was flat lol!
  1. Engine management light on with fans running and 2 fault codes. HELP?!
    By Crunch in forum A3/S3/Sportback (8P Chassis)
    Last Post: 29th September 2011, 12:22
  2. Error code 01139: with Eng Management Light ON HELP!!!!!!
    By jimbojet in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 6th April 2011, 11:45
  3. abs and esp light on with engine management light
    By madsad1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th May 2010, 18:22
  4. help with engine warning light
    By edgerfs in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th April 2010, 22:21
  5. Help Engine Management Light On
    By taj in forum TT/TT-S/TT-RS Forum
    Last Post: 13th January 2005, 20:07
