EM TuningMonster Motorsport
Results 1 to 19 of 19
Like Tree1Likes
  • 1 Post By badger5
Thread: Reinforce XS Manifold Welds
    Aug 2009
    Cheltenham
    335
    Hello,
    Is there anyone around the Gloucestershire area who is able to reinforce the XS V2 K04 manifold welds, the Franken Manifold has to go!!
    I am not after a freebie, just good welding.
    Barks
    Reesy's Avatar
    East Sussex
    3,604
    Quote Originally Posted by Barks View Post
    Hello,
    Barks
    Speak to s3 Dave. He isn't local, but Prawn + Westy have gone to him, might be others as well, and he has a same day it comes in its back out turn around, all for a good price for what he does.
    Aug 2009
    Cheltenham
    335
    Quote Originally Posted by Reesy View Post
    Ah Yes, I had my rear Tie bars from Mr S3 Dave, Thanks
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    bill is in gloucestershire.
    RIP S3dave
    May 2004
    nr Glos
    7,156
    hello................
    you do know where I am Dave..
    like this> nickle rod used
    dont you?
    eh?
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    Aug 2009
    Cheltenham
    335
    I do, I do Bill, I haven't been on the forum for a while and didn't think it was a service you offered!!
    RIP S3dave
    May 2004
    nr Glos
    7,156
    lol.... me weldy things..
    done 3 relentless so far for assorted folks
    sambryant likes this.
    bill@badger5.co.uk
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    I'm thinking of buying a relentless manifold, how come you have to re-weld them? Are they THAT bad?
    1.8 litre porsche eater!
    R-Tech Terrorist Squad - 265bhp & 275lbft
    S321BAM's Avatar
    I lost the rod lottery
    May 2010
    Plymouth
    102
    Bill.....why is nickel rod used??? I'm a TIG welder by trade and curious???? thinking of investing in one of these myself, do they all need reinforcing or is it pretty obvious when you open the box??
    Cheers, Chris
    RIP S3dave
    May 2004
    nr Glos
    7,156
    Quote Originally Posted by S321BAM View Post
    Cheers, Chris
    I should say hi-nickle content stainless rod to be precise. Used for dissimilar materials and supposed to be more crack resistant as a consequence.
    Relentless dont backpurge their thin wall material welds.. and the most common area of failure is around the collector, as it gets the hottest. (like yellow hot!)
    The "hope" is the additional welding around their welds (I back purge when going over them also) is to get thicker weld on the joins and to try and get full penetration weld in that area.
    I say "hope" as its welding on top of their welding.. and quite what *actual* material it is is unknown.. I know what they claim it to be but I am a sceptical bugger, hence using the stainless/nickle rods for dissimilars on them. I use the same rods for welding stainless/ferrous to cast components also... 100% reliable so far.
    The V3 relentless is supposed to be better, but I have'nt seen one, and heard they still have'nt backpurged their welds despite changing material to a titanium induced 321 stainless.. (which sounds great as a sales pitch, but full properties will never be achieved unless full solution annealed to normalise welds........ which they dont do, not likely ever to)
    bill@badger5.co.uk
    S321BAM's Avatar
    May 2010
    Plymouth
    102
    looking at the original welds on the photo, looks like they don't use filler wire at all and just 'fuse' the joints together hense why they would crack. By saying back purge do you mean filling the inside of the manifold with argon??
    RIP S3dave
    May 2004
    nr Glos
    7,156
    yes backpurge=argon inside tube..
    they do "just" fuse the welds in most joints, without penetrating the thin 1.2mm wall thickness.. SO... @ welds its very thin without the full penetration, and if they did happen to break thru, the inside would coke up and oxidise without backpurge anyhow.
    Fusion alone is'nt bad, so long as you make sure its 100% penetration and not an undercut sagged weld bead.
    (I used to work for an engineering company as their Engineering Manager, and one of the products I did back in the 90's was autogenous welded 316L tube to make a coriolis mass flow meter, and this involved TIG fusion butt welded joints, no filler, and was 100% inspected to ensure full penetration etc etc.. All materials were post welding full solution annealed however also to ensure no heat effected zones as would otherwise occur. When I tensile tested the process whilst re-engineering the products production we had no loss of parent material mechanical properties... Just as good as if it had never been welded. Handy when the device when operating vibrated at 120Hz and would cycle >10.4million oscillations in a day... If there was a weakness it would crank in minutes/hours without the work we did to them)
    I guess you dont do back purge welds on stainless where you work?
    bill@badger5.co.uk
    Speedy Steve's Avatar
    Nov 2008
    Leicester
    1,246
    So basically save money and get the version 2 and then get you to weld it then Bill?
    Ive been Badger 5'd
    Can we break the magic 300?????? In a word Yes 314 BHP 249 lbft at Badger 5
    steves is way quicker than any stock turbo'd s3 i have driven
    I only date skinny Women! They keep my power to weight higher...
    S321BAM's Avatar
    May 2010
    Plymouth
    102
    only had to purge weld a several times over the last 16 years, fabricated one off special purpose machinery were purge welding isn't really required. Remember a job years ago someone fused all the joints on a stainless water system, by the time it got to czech republic the majority of the welds had split, around 100m of pipe work!!
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    I've JUST ordered one from relentless in America, If i post it to you would you weld it up and send it me back? I'll cover all costs obviously.. And it'll give you chance to check out a brand new one
    Ben
    RIP S3dave
    May 2004
    nr Glos
    7,156
    ok, no probs
    bill@badger5.co.uk
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    Cool mate, cheers. I'll give you a ring when it arrives
    Ben
    lovemelongtime's Avatar
    Jun 2012
    Horsham
    335
    Hi Bill,
    How much for the welding fella? Can you PM me please? Also can you fit the v2 if so would you recommend doing the rods and piston rings?
    RIP S3dave
    May 2004
    nr Glos
    7,156
    Quote Originally Posted by Martin Henson View Post
    Hi Bill,
    rods - always yes..
    rings, only if it needs them (often not)
    bill@badger5.co.uk
  1. URGENT ADVICE - MANIFOLD RHD??
    By StevieBogan in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th January 2005, 19:52
  2. Manifold Boost Pressure Switch
    By mtsakmakis in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th December 2004, 20:30
  3. Dahlback Racing Inlet Manifold
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th October 2004, 20:14
  4. Garrett manifold
    By saldale in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2003, 13:38
  5. Polished inlet manifold
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th March 2003, 01:00
