Sky InsuranceAH Fabrications
Results 1 to 24 of 24
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,066
    Fitting a B5 tip and Hybrids
    Just an heads up for guys fitting the b5 tip to their Hybrids,,,,
    The wall thickness where the billet adapter goes, is stupidly thin on these and it is easy for you to puncture the grub screw through the wall.....
    I had originally gone through it but then backed the grub screw out and decided to use more silicone for a seal...
    the mechanic that fitted my engine must have tightened it back up and clamped the bottom of the tip before it was in its final resting place resulting to this...
    So the lesson is go very steady with the grub screw and tighten the b5 tip on the billet adapter last when everything is fitted and is in place..
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,041
    F00k me how was that not ingested into the turbo!!
    <tuffty/>
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,066
    Most of it was still stuck to the silicone behind it, but a bit must of got blown through...
    It spins freely and has zero play so i guess i was lucky....
    S3 Paul's Avatar
    Oct 2006
    2,759
    How big are the grub screws?
    Are there 3 screws or just the one?
    Im running a hybrid and im holding out for this new "budget tip " from bill to break cover...
    Noggy Blue 2001 S3
    www.badger5.co.uk
    May 2004
    nr Glos
    6,950
    seen this myself.. glue it on.. grub screw is not required to be "tight" as it sits in the groove so cannot allow the billet to come off.. Silicon sealer will hold it plenty tight enough.
    daft thin machining tho..
    Check out the ever Growing eBay Shop>
    http://stores.ebay.co.uk/Badger-5-LTD?_trksid=p4340.l2563
    bill@badger5.co.uk
    S3 Paul's Avatar
    Oct 2006
    2,759
    I thought it would be there just to be safe and stop it actualy coming off.
    Grub screws are usualy only small allen key sized ( half the size of the bolt ) so to over tighten would feel wrong.
    I will check mine tonight... see if the wall is as thin
    Noggy Blue 2001 S3
    www.badger5.co.uk
    May 2004
    nr Glos
    6,950
    M4 grub screw in my TIP
    bill@badger5.co.uk
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,079
    jesus that must have been tight :S
    I'm sure my CR hybrid isn't quite THAT thin in the inlet, although I could be wrong.
    Sreiously lucky that didn't go through the turbo Davidz!
    beachbuggy's Avatar
    Surrey
    1,727
    If they use a standard compressor housing then yes it is incredible thin in the recess. My hybrids have a 2.5mm thickness on the inlet after machining and the recess is a tad under 1.5mm thus at recess it's 1mm thick! I'm not surprised the grub screw went through. I was also worried that a T clamp done up on a stock clamp would distort the inlet also.
    I guess that was your problem though Dave!
    Decided what you'll do to fix it?
    Westy's Avatar
    Double Dark Side! Diesel & 8P
    Dec 2008
    17,170
    This just seems like another thing that lets down the K04 hybrid!
    8P A3 TDI - 220bhp - 335lbft
    A3 Maintenance Thread
    S3 Build Thread
    beachbuggy's Avatar
    Surrey
    1,727
    Quote Originally Posted by Westy View Post
    To be fair , while its possibly easier to do, anyone with a k04 can damage it by over tightening something, it's not the hybrid or b5 tip fault but an over excited fitter! Correct fitting is everything! And fitting the b5 tip correctly would actually strengthen the inlet.
    Westy's Avatar
    Dec 2008
    17,170
    Quote Originally Posted by beachbuggy View Post
    In this case though its an over excited machinist!
    S3 Build Thread
    beachbuggy's Avatar
    Surrey
    1,727
    Very possibly I agree! If they leave the stock clearance then whilst it's thin it should be ok. Shame this has happened though, I guess though it's a lesson learnt just hope Dave can fix it without taking the turbo off.
    v5 tt's Avatar
    Aug 2011
    Southampton
    85
    i have the b5 v1 tip the grub screws are small i think a larger grub screw covering more service area would
    be more secure and help not to punch a hole through just my thoughts
    www.badger5.co.uk
    May 2004
    nr Glos
    6,950
    not every hybrid westy
    same as everything..... they are not all the same.
    bill@badger5.co.uk
    www.badger5.co.uk
    May 2004
    nr Glos
    6,950
    Quote Originally Posted by v5 tt View Post
    grubs screw size is identical on v1 and v2 and are deliberately located to sit into the groove, so they can be "nipped" up and as such would make it impossible to pull off, as its sat in the recess
    locating anywhere other than the groove relies on the grub screws being "tightened" to bite into the inlet, which to me is worse, and less reliable a location. When installed with the smear of sealant, this does the job of securing it in the main.
    bill@badger5.co.uk
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,353
    So was that the strange sound you heard then Dave
    Was 531bhp 8L S3 thats going to break the 600+ bhp Club then break something else. Lets see what this OD HTAGT3582r can do
    My S3 Twists Drive shafts for fun.
    FOR SALE
    Sparco Torino 2 sport seats
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts
    , relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    www.badger5.co.uk
    May 2004
    nr Glos
    6,950
    This picture is different machining to ones I have seen.. where the larger bore for the 2283 wheel is only machined that larger OD to the end of the tip of the comp wheel blades, then reverts to a smaller diameter so not being too thin by the groove.
    Who made this one?
    I have seen a CR one like yours, but mostly like I describe because of this issue it causes.
    bill@badger5.co.uk
    Sep 2011
    Isle of Man
    175
    I have just had my CR one fitted and had the same issue. Screw wasn't that tight metal just so thin in that area. Redrilled closer in and all fine now, plus sealant.
    2000 Audi S3 Black. Engine rebuilt Wossner internals, custom map, B5 3" TIP, Haldex blue, sport shifter, H&R ARBs, Green filter, 8P gear knob, 18" RSTTs, K-sport 8 piston 330mm brakes Ferodo pads front & rear, Nitrac disc rear, AP coilovers, adjustable tie arms, Powerflex bushes all round, yellow mount, LCR splitter, 3" DP & decat, 006p & Liquid CUBE, Forge FMIC, 550 injectors, CR Hybrid Turbo Stage 4 and Custom manifold
    Audi S3 (310 bhp & 311 lbft)
    Aston Martin V8 Vantage
    CBR 600RR (08 )
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,066
    Who made this one?
    lovely CR Bill....
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,066
    Ive taken more potential loose bits out and give it some red rtv sealent wiped all the excess and let it set overnight without fitting anything, feels solid now, not sure if it was the noise Andrew/Dan, we will see, ive got a turn or 2 on the bearing housing too so im hoping the noise has stopped....
    www.badger5.co.uk
    May 2004
    nr Glos
    6,950
    lovely CR Bill....
    damn.. inconsistent machining..
    bill@badger5.co.uk
    Chugger
    North Devon
    2,716
    Eek, I can vouch for just siliconing it... I can't get mine off after using high temp sealant. All I did was thread lock the grub screw and nip it up, although I didn't have to worry about the thin walls of a hybrid
    57 A3 2.0 TDI Sportback (140)
    Sep 2011
    Isle of Man
    175
    Mine was just sitting on while the engine was out on the bench the TIP slipped and I got a smaller grove than Dave just from the weight of the TIP, then noticed just how thin the metal is there. Almost tin foil !!!
    CBR 600RR (08 )
  1. Just fitted my TIP and Jetex
    By Danman1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th June 2012, 17:45
  2. K03S Turbo finally fitted and neuspeed tip and wow!
    By Customboy in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd March 2012, 21:10
  3. Badger-5 tip and maf fitted....
    By BENJAMIN in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th October 2011, 15:44
  4. Remap - before or after fitting TIP and DV
    By Phil-UK in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd August 2011, 09:30
  5. Just fitted a N75J Valve and ............
    By Daveiow in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th July 2006, 14:28
