Sky InsuranceEM Tuning
    Oct 2009
    21
    s3 fitting 18 x 9.5 all round ?????
    hi folks i found a thread on here saying they might not fit but there was one for sale recently with them on and it looked perfect, i tried to contact the seller but got no reply.
    the wheels will be brand new from 3sdm and tyres will be 225/40/18s the same as the one in the pictures ( this is the one that was for sale, any help and advice will be greatly appreciated as i need this stance badly
    thanks guys
    [IMG][/IMG]
    [IMG][/IMG]
    Jun 2012
    289
    You can get those wheels in 8.5 if 9.5 is too wide for the front mate
    Oct 2009
    21
    anyone ????? someone on here must of had 9.5s all round at some point or at least tried ???
    gareth_oau's Avatar
    Dec 2008
    Perth, Australia
    216
    I'm running 8.5" on the front of mine with 5mm spacers, and the inside clearance is thinner than a cigarette paper - but I think this is partially due to the Goodyear Asym 2s I'm running (235/40/18) which have a large rim protector on them.
    The outside is within around 5mm of the guards.
    If you go 9.5" on the front you will definitely need at least 10mm spacers to give inner clearance (and not accounting for rim protectors on tyres), but this will then have the outside of the rim sitting at least 12mm outside of the guards.
    You won't be able to run it lowered
    2007 RS4
    2000 S3 APR'd
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    You could do it,but you would need to get your arch's rolled alot,for it not to look stupid,you would get some rubbing isues but would work,what et are they?,or like someone else said get the 8.5 fronts,would look better cheeper,and wider on the rear is better stance in my book.
    Audi S3- 1.8T Quattro
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
    Danio's Avatar
    AUDI-MANIACS.COM
    Aug 2011
    Skelmersdale WN8
    187
    Depends what collies will you use. My mate has got KW V3 collies and 9.5J all round ET 38 with 30mm spacers on the back and 25 on the front. And I would say not much space left between strut and the wheel.
    Currently not in the country
  1. Rough price help.. Disks and Pads all round?
    By Dec in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st March 2010, 16:39
  2. Performance pds and discs all round
    By Fireyjack in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 20th March 2010, 01:34
  3. A6 pads and discs all round, how much?
    By sidibear in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 30th July 2009, 22:58
  4. Need new rubber all round!
    By A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th January 2009, 17:09
  5. New discs and pads all round. Is this a good price?
    By imported_gek in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th May 2006, 14:37
