Had a problem with a faulty coil pack and some damaged wiring near the coil pack, but since fixing this the car has been running fine. However i have the following codes for the engine.
Also today the esp light came on and i have a brake pressure sensor fault.
Chassis Type: 8L - Audi A3/S3
Address 01: Engine
2 Faults Found:
17956 - Boost Pressure Regulation Valve (N75)
P1548 - 35-10 - Open Circuit - Intermittent
16795 - Secondary Air Injection System
P0411 - 35-00 - Incorrect Flow Detected
Readiness: 0000 0000
Address 03: ABS Brakes
Component: ESP
1 Fault Found:
01435 - Brake Pressure Sensor 1 (G201)
57-10 - Electric Circuit Failure - Intermittent
Thanks in advance.
Address 01: Engine
2 Faults Found:
Component: ESP
1 Fault Found:
Thanks in advance.
