right so this is how the code came up on my scanner.
16505.p0121 Throttle/pedal position sensor/switch a curcuit-G69:range/performance
when i type the error in to ross tech it says this.
[h=2]16505/P0121 - Throttle Position Sensor (G69): Implausible Signal[/h][h=4]Possible Symptoms[/h]
- MIL on
- Poor engine performance
[h=4]Possible Causes[/h]
- Wiring Harness issue
- Failed Throttle Body
- Failed ECM
[h=4]Possible Solutions[/h]
[h=4]Special Notes[/h]
- For some vehicles, there may be a TPI with instructions on replacing the terminals for the throttle body.
- Some ECMs may have a firmware update to address this issue during cold weather.
and the other error is 00575 intake manifold pressure. thats pretty much all it says on the scanner and when i type it in to ross tech i get this.
[h=3]00575 - Intake Manifold Pressure: Control Limit Not Reached[/h][h=4]Possible Symptoms[/h]
- Sudden complete loss of Power
- Reduced Power
- Hoses incorrect connected, disconnected, blocked or leaking
- Pressure Unit for Turbo Charger defective
- Solenoid Valve for Boost Pressure Control (N75) defective
- Check Hoses
- Check Pressure Unit for Turbo Charger
- Check Solenoid Valve for Boost Pressure Control (N75)
- Check Basic Setting > MVB 011
[h=3]00575 - Intake Manifold Pressure: Control Limit Exceeded[/h][h=4]Possible Symptoms[/h]
- Reduced Power
- Charge Pressure too High
- Turbo Charger defective
[h=3]00575 - Intake Manifold Pressure: Control Difference[/h][h=4]Possible Symptoms[/h]
- Check Hoses
with it saying about the n75 not working that would be correct wouldn't it because its not plugged in, also the charge pressure to high that would be correct as well because of the new turbo, at a guess anyway.
