Chris NottVolks Autos
    Jun 2012
    Torqauy
    100
    K03 shaft question!!
    Hey guys i finally got a second hand k03 turbo for my audi a3 agu engine and it seems fine apart from the shaft with the fan on has movement from side to side its not alot maybe 1mm if that its only side to side not in and out but would it be ok or shall i get my money back?? Any info would be great.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    A little movemoent side to side is fine... excessive movement in and out would be bad but as you don't have that you should be fine
    <tuffty/>
    Jun 2012
    Torqauy
    100
    None in&out but about 1mm side to side if that!!
    May 2011
    reigate surrey
    191
    in out is a big problem, side to side is ok with 1mm, i was dead lucky when i changed my TIP i checked my ko3 and had no movement at all, 121k too. good luck with it.....
    Customboy's Avatar
    Jan 2012
    SE London
    836
    Sounds ok to me once oil feed is fitted and running should sort it out should of asked me got my ko3 sitting in my shed only covered 80k
    p
    THE BLUE BEAST, TAKEN FROM ME, GONE BUT NOT FORGOTTEN
    RTECH STAGE 2 REMAP NOW RUNNING 223 BHP AND 253 FTLB OF TORQUE,
    SUBARU IMPREZA WRX ESTATE SOON TO BE RUNNING 340 BHP
    ANTI LAG/LAUNCH CONTROL/MAF LESS/ LOVE IT !!
    Jun 2012
    Torqauy
    100
    Cheers guys as always its put my mind at rest, it only cost me £88 delivered so worth a punt at that price getting it on next wkend so wel see lol.
  1. K03s shaft play
    By takworldwide in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th May 2011, 11:17
  2. k03 turbo question
    By gaz71 in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th August 2010, 22:07
  3. k03s question
    By audia3turrbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th April 2010, 20:40
  4. Gearbox + drift shaft question...
    By Shy19s in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th June 2008, 20:36
  5. k03s turbo question
    By Bellic in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st July 2007, 23:32
