JMB RetrofitsAH Fabrications
Thread: Oi leaking
    tommyps3's Avatar
    Jun 2012
    Oi leaking
    Hello, ive recently bought my 2001 amk engine s3 and just replaced the turbo on it, it seems to be leaking oil on the bottom oil pipe round the gasket and bolts, just wondering wat gasket is best to use and if there is anywhere else it could leak from?
    Also after replacment the exhaust was seemingly full of oil most of it has burnt off just winderin how long does it normally take to completely stop!
    Any info much appreciated! Thanks
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    The only gasket to buy is an OEM one... anything else will leak...
    Assuming the oil in the exhaust is the result of the previous turbo's failure (turbos seals at a guess) then it will burn out eventually... only real problem is that it could damage the CATs... realistically you would have emptied the oil from the exhaust and probably the charge pipe system too (so both SMIC's and all the hoses) as blown turbo seals tend to fill all this up rather quickly... its rather important that you clean out all the oil as this will continue to be blown into the engine and will affect performance of the car...
    <tuffty/>
    tommyps3's Avatar
    Jun 2012
    Yea i cleaned out all the pipework and ic's etc before refitting it all back together, as for the gasket the one that came with the new turbo was a card type gasket and ive read a few threads saying to use a metal one so thats what i done and its leaking still! Cheers for the reply
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,556
    Quote Originally Posted by tommyps3 View Post
    The cardboard ones are rubbish... OEM metal one all day long... I even use one on my GT30 turbo...
    I would be concerned if you have oil still going into the exhaust if you have cleaned it out... it may take a few heat cycles to burn all the residue out of the exhaust as the oil is probably pooling all along the exhaust system... just keep an eye on the oil levels for a little while until you are happy its all ok
    <tuffty/>
    tommyps3's Avatar
    Jun 2012
    Ok il order a new gasket monday then get that done! And i think il give the ic pipes etc another clean for peace of mind! Cheers again
  1. OIl Leak - Help Please
    By cbass in forum General Technical / How To
    Last Post: 20th September 2004, 20:29
  2. air leak noise s3
    By peteA3tdi in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th May 2004, 00:26
  3. Water Leak on Drivers Side
    By S3DBW in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th April 2004, 07:20
  4. Power Steering Fluid Leaking A4 2.8 1997
    By bradmcw in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th March 2004, 12:53
  5. Help, S4 water leak!
    By Futureman in forum A4/S4 forum(B5 Chassis)
    Last Post: 31st August 2003, 20:11
