Badger5JMB Retrofits
    James TQ's Avatar
    Apr 2012
    Essex
    548
    anyone have a guide to remove the injectors please?
    as title says really, bought myself a ultra sonic cleaner and wanted a guide on how to go about it, will be greatly appreciated!
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,511
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,569
    TBH its pretty straight forward... Remove pipe to FPR, unclip wiring harness, undo 2 x 5mm cap bolts hold the rail to the inlet mani, gently pull on injector rail to pull injectors from the mani (a little spray of silicon oil or wd40 down the plastic bosses will help ease the seals if its tight...), undo the clips that hold the injectors to the rail (take note of how they fit... there is a slot in the top of the injectors for the clip to slide into), gently pull the injectors out of the rail... sometimes the o-ring comes off and stays in the rail but thats easy enough to put back on after)
    Don't do this after driving the car as the engine will be hot and there will be pressure in the fuel line... pressure will drop off a little after a bit of time but expect fuel to leak out a bit when you remove the injector... make sure you have something to mop the spilt fuel
    <tuffty/>
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,569
    ...or this... maybe I should have searched first ;P
    <tuffty/>
    James TQ's Avatar
    Apr 2012
    Essex
    548
    Thanks guys, Hopefuly this bump help my mpg problem...I'll put a picture up later of how much muck came out !!
  1. How do you remove the injectors? 08 plate S3
    By Sock in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th May 2011, 19:45
  2. Has anyone got a guide for doing the suspension?
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st March 2011, 14:01
  3. Does anyone have a wiring diagram for the brake lights on an A3?
    By sixsr in forum General Technical / How To
    Last Post: 24th February 2009, 10:11
  4. Does anyone have any more pictures of the new facelift a3 s-line?
    By bumble in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th August 2008, 10:45
  5. does anyone have a vag com in the north east
    By jase0851 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 20th July 2007, 18:09
