JMB RetrofitsChris Nott
Results 1 to 9 of 9
    James TQ's Avatar
    Apr 2012
    Essex
    548
    serious MPG problem!
    last week i put 3/4 of Shell Vpower in the quattro... just over a week later im just on petrol light, got 220 miles on the trip averaging 21.7mpg!! i have replaced the breather hose and cant find any more obvious damaged pipes.... at my whits end it shouldnt be that bad?! its been town driving and the occasional 'Boot' but nothing major at all!!
    also, the third gear seems slugish... my friend has a mk5 fiesta zetec S and in third im not pulling away from it.... supposed to have 180bhp standard.... doesn't feel like i have anywhere near it!! any ideas to get me pointed in the correct direction please guys?
    Thanks!!
    Edit: does not have a map and is standard.
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,896
    If it were mine I'd be plugging the vagcom in to see if anything comes up,cleaning your injectors and throttle body also the maf sensor would be first on my list,has the car been serviced regularly ?
    Also buy a new DV if it still has the original one if it was me.
    Feb 2012
    bedfordshire
    748
    Could it be in limp mode disconnect the battery for half hour then try your car should reset most faults
    James TQ's Avatar
    Apr 2012
    Essex
    548
    Replaced the dv with a 008 recently. Not sure on servicing as I have owned Ot two months. For the first six years l it's life it was serviced by Audi then no other papers after that as fare as I'm aware untill I bought it it had one put on it, on vagcom what sort of things would I be looking for? Thanks
    Apr 2012
    605
    air leak poss as thats affects fuel etc
    Pushing the limits..
    Jan 2011
    Australia
    1,316
    Add Sevv on Facebook
    check your EGT sensor too they seem to go fairly common issue
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,896
    Quote Originally Posted by James TQ View Post
    Clear any faults then take it for a drive and scan it again,you should see whats up then unless it is a leak in the miles of pipes,so your car could be six years without a service/haldex oil change/timing belt/water pump ?
    James TQ's Avatar
    Apr 2012
    Essex
    548
    Cambellt was done not so long ago, oil was changed before I got it, I'm going to do coolant soon, how hard is it to change the haldex and gearbox oil?
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,896
  1. Mpg problem 2.0 TDI
    By Sheikh in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th November 2011, 20:10
  2. seriously baffling problems
    By superkarl in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th August 2011, 16:01
  3. A4 DIS MPG problem
    By Hedley88 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st March 2011, 19:34
  4. DIS MPG problems
    By Clach in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd September 2008, 18:45
  5. Help! Serious whining problem
    By RobG in forum General Technical / How To
    Last Post: 22nd August 2004, 12:32
