Monster MotorsportChris Nott
Results 1 to 7 of 7
    James TQ's Avatar
    Apr 2012
    Essex
    546
    wheel housing splash guard replacement guide and rust/corrosion tip!!
    so i decided to replace the wheel housing/protector in the arch above the wheel as the bottom of the bumper kept detaching and popping to the side. the corrosion prevention bit came when i took the panel of, there was loads on wet mud and leaves caught up and packed in at the bottom so even if you don't need to replace the part it would be wise to take half a hour to remove all this. just need to remove the 3 screws and the panel will pull forward enough to get to it!
    replacing the panel was very straight forward, there was around 8 screws to remove, then transfer the 2 clips from the bottom of the old one and slot the thing into place.
    i didn't need to take the wheel off but my car isnt lowered, it would of been 10 times easier with the wheel off though!
    the old one.
    once removed, this is what was packed in! below the leaves is mud and acorns!
    more than i thought!
    old&new
    the clips that need to be carried over.
    the new splash guard lined up and bolted back.
    boost-addict's Avatar
    Aug 2011
    977
    how much roughly is the liner from audi??
    James TQ's Avatar
    Apr 2012
    Essex
    546
    Quote Originally Posted by boost-addict View Post
    £16.28 plus vat
    rhubarb4's Avatar
    Certified Jardo Slayer
    Mar 2008
    Midlands
    1,707
    No way they quoted me £48 + vat for the S3 version because of the vent in it.
    Chris.
    <img src=http://cdn.as-static.com/vb/images/smilies/scared2.gif border=0 alt= title=Scared2 class=inlineimg />
    i wear ladies underwear to work.
    James TQ's Avatar
    Apr 2012
    Essex
    546
    get one of the a3s and a stanley blade? = one vent lol?
    rhubarb4's Avatar
    Mar 2008
    Midlands
    1,707
    That was what I was thinking as the vent is ok so I may just bond it in if the liner fits.
    James TQ's Avatar
    Apr 2012
    Essex
    546
    remove the old one once you get the new one and just line the vent up and score it onto the new one? if there the same sahpe you can taleys make new holes for the screws?
  1. Engine Splash Guard and MOT
    By Gavin G in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th May 2012, 20:39
  2. G62 Coolant Temperature Sender - Replacement guide
    By Neil_S in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th December 2007, 20:40
  3. AGU Cambelt Replacement Guide
    By cha1n in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2007, 18:30
  4. Warranty and Rust
    By recomdos in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th August 2007, 13:22
  5. Powerflex replacement bushes and lowering springs for a4 2.6Q
    By RICHARDJC in forum A4/S4 forum(B5 Chassis)
    Last Post: 26th May 2005, 00:00
