Volks AutosEM Tuning
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    671
    s3 lowering question
    hi all,
    Due to a company van, my s3 is going to be having abit of cash spent on it now i dont have to fuel it like 30+mile aday.
    just wondering when i drop it on coilovers, (it will be low) what anti roll bar do i need, or drop links etc.
    Cheers.
    JtotheD's Avatar
    Events Moderator
    May 2011
    Bournemouth, Dorset/ Wallingord, Oxon
    907
    what you should invest in is a decent set of adjustable rear tie arms to adjust the negative camber that happens when you drop an s3! i got mine through a guy on here called s3dave who makes them. had no issues with mine. see my build thread to view them.
    S3 8L Ming Blue 273bhp & 294lbft h
    Build/project thread
    check it out!
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    The only thing you'll need depending on how low you go are (as JtotheD said) rear adjustable tie bars as there will be excessive negative camber. Unfortunately I don't think Dave makes them anymore though. You might need adjustable drop links if your standard ones hit your lower wishbone, Ive lowered mine probably 45+mm and mine dont knock so you'll probably be fine.
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    s3clarke's Avatar
    Money grabbing s3!
    Jun 2012
    Bromsgrove
    671
    thanks for your help lads.
    Apr 2012
    Tunbridge Wells
    105
    Quote Originally Posted by s3clarke View Post
    As above, all you'll need to run safely will be adjustable tie bars! Go for the Forge ones, excellent quality and great value for money!
    Make sure you chuck those rear coilover adjusters in the bin as well if you're really wanting to sit low!
  1. Lowering Question
    By MarcQuinlivan in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th September 2009, 08:57
  2. Lowering question (A3 on 17's)
    By Keeno in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd April 2009, 13:46
  3. over asked lowering question !
    By a4cam in forum Handling
    Last Post: 16th December 2007, 12:51
  4. Alloys/Lowering Question Plz help!
    By A3_Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th September 2006, 17:13
  5. Lowering Question - 50mm Eibachs on order
    By dgannon69 in forum A3/S3 Forum (8L Chassis)
    Last Post: 22nd February 2006, 06:47
