Chris NottMonster Motorsport
Results 1 to 16 of 16
    Apr 2012
    93
    Question Loud wining/whizzing noise on start up
    hi all as above, my s3 makes a loud wining noise when first started, seem to be only when its cold or bin left for a bit, my m8 said it was the cold start on the air compreser, ive scearched threads for cold start on the air compreser but no joy, its not coming from the starter or aulnater, i could not really tell if it was coming from the air con pump, its a mad loud whining/drilling noise and it sounds pants. it goes off when you drive off or leave it long enough it will seem to wind down and the revs drop to normal, ive comw across threads about sai pumps. could this be wots making my mad noise? can it just be unpluged or sumthing? thanks in advance
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,828
    i started to get the same a few days ago. at a guess i think its the SAI but not 100%
    Jan 2011
    N.Ireland
    149
    Think this is common mine does it aswell and it's related to the oil pick up maybe someone else can confirm this? It does no harm as far as im aware.
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,828
    oil pick-up??
    My old pump isnt even a year old. I swear I could right a book about the problems with these cars lol
    Apr 2012
    93
    i think mine is sai after reading on hear, but like you id like to be 100 percent sure m8.
    Quote Originally Posted by Paradox1 View Post
    Jun 2010
    East Manchester In the Hills !
    597
    Sounds like the secondary air intake on its way out. All it does is allow the CAT in your exhaust warm up quicker, hence if you rev the engine from cold it will quieten down quicker and the revs will drop slightly. Search on uk-mkivs.net as there is a how to over there on how to fix them. The noise should be coming from the drivers side front wheel well
    Apr 2012
    93
    hi m8 thanks for reaply, it sounds like its come from the front of the car down by the air con pump , i carnt quite pip point it, it a loud hover/drill type sound.
    Quote Originally Posted by lgooch View Post
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,115
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Mehh feck fixing it when it's not really required/needed!! lol Forge Motorsport | Alloy Fabrication Ordered me one of these in
    Jun 2010
    597
    does it sound like this. if it does then you have your answer. The SAI is not far from the air con pump but you would easily be able to tell if it was the air con pump by turning it on and off.
    Audi secondary air injection pump - YouTube
    Jun 2010
    597
    Aug 2010
    bradford
    1,239
    mine does the same too but its getting louder my pick up pipe is clean and air con working fine so god nose plus i dont have a secondry air pump on my amk
    350bhp & 316ftlb BBT new k16 7+7 blade hybrid turbo, Welly cooler, jetex filter, relentless ported v3 manifold 3" downpipe & de-cat, liquid gauge, r32 rear arb, AGU ported and polished Head, 550cc injectors, kw v2 Coilovers, s3dave tie bars & heat sheild, milltek cat back, I.E forged rods, brembos, inline fuel pump, v3 badger 5 tip, devils own WMI kit, AGU pistons, rear grooved discs & brembo pads, ds2500 pads & EBC ultimax disc, stack boost gauge
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,027
    If its a high pitched squeal type noise its the fans... when it does it again, turn off the aircon by hitting the econ button... if the noise goes its the fans..
    Mine does this
    <tuffty/>
    Apr 2012
    93
    hi m8 thanks for the reaply, yes thats the sound its making, will it be ok to just unplug the wires ?
    Apr 2012
    93
    hi thanks for reaply, can i just unplug it as simple as that? will the engine mangment come on? will the car still run ok? thanks.
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,828
    i think if you unplug it you may get a EML but thats all
    Jun 2010
    597
    Quote Originally Posted by HOTTIGGER View Post
    Yes take the multiplug off. Start your car and if the noise is not there then you have pinpointed your problem
  1. Loud noise when starting my a2
    By hulland in forum A2 forum
    Last Post: 11th July 2010, 00:08
  2. High pitched noise when starting from cold
    By ajek in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th November 2004, 15:00
  3. engine noise on start up
    By S3JUS in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd November 2004, 18:43
  4. noise when starting
    By JamesA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th May 2004, 08:02
  5. Re: Noise when starting
    Last Post: 15th May 2004, 23:18
