Badger5Volks Autos
Results 1 to 8 of 8
    imported_alecblack
    Braking problems
    Hi All,
    Can someone help me out here?
    I am getting vibration through my steering wheel when I am braking but this is only happening when my speed is hitting 50-60mph when i am below or even above that the problem does not exist. I thought it may be my tracking but kwik fit assured me this was not the case. my back brakes (discs & pads) were replaced 3 months ago and the mechanic assured me then that my front brakes were ok and still servicable.
    Any suggestions/anyone had this problem before?
    paul_brad's Avatar
    Apr 2004
    Leicester
    365
    Re: Braking problems
    It sounds to me like the front discs are warped.
    Although there wouldnt be any vibration at slow speeds, can you feel the discs touching on and off? (It helps when there is rust on them to hear the scrape a little better!)
    Aug 2003
    Kent
    123
    What are your tyres like???
    I had a slight vibration when coming off the throttle around 50 - 70 mph, shortly before replacing the front tyre!
    After a new set of boots, no vibration!! They had worn a lot more on the inner side of the tyre, which could have been the cause!!
    imported_alecblack
    Both of your explanations sound valid.
    kwik fit said to me that the discs were warped without looking at them but i always get a second opinion as they cannot be trusted. My tyres are slighlty more worn on the inside and outside edges, so this could also be the problem.
    cheers guys
    Dec 2004
    North London
    209
    Even though the brakes are serviceable they could still be warped.
    Aug 2005
    surrey
    38
    also to throw an another option, you could have lost a wheel weight thus throwing the wheel balance, happened to me once before. worth checking this before spending money on brakes at kwik sh!ts say so.
    peteA3tdi's Avatar
    Mar 2004
    the rose and crown
    406
    if the discs are warped then you should still get the vibration over 60mph , take the car to a MOT station and get them to check on the brake rollers as this will show if they are warped or not, it maybe the lower arm bushes
    imported_alecblack
    Got my car serviced yesterday and it turns out the problem was my discs rusting on the outside edge. This was a relief as it only cost 30 to skim the discs and it has now sorted the problem.
    cheers guys
