Badger5Sky Insurance
    Jul 2011
    boost brake line 1.8t agu
    can i change this hose with aftermarket sillicone hose with same diameter? only the section that come from the manifold to the check valve
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,595
    Sort of... problem is that the larger ID silicon vacuum pipe isn't very stiff and as this pipe sees vacuum then it can collapse which of course would be bad...
    You can get smaller ID in proper laminated silicon hose though and is what I have used on big turbo builds in the past
    <tuffty/>
    Jul 2011
    Well i installed a sillicone hose that is ID8mm OD14mm worked perfect
  1. Brake Lines
    By chasdrury in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th August 2008, 17:04
  2. Damaged brake line help
    By sherry in forum A4/S4 forum(B5 Chassis)
    Last Post: 24th May 2008, 14:21
  3. Brake lines for an Audi S4 Avant
    By robbie5 in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th March 2008, 17:06
  4. Black Diamond Brake lines
    By billybravo in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th January 2008, 14:53
  5. Brembo brake line fitting!
    By scib4 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th April 2007, 23:04
