Volks AutosAH Fabrications
Results 1 to 9 of 9
    Jan 2012
    41
    Clutch on a 1998 A3 1.8t AGU help
    Anyone kindly help me I got to change clutch on my A3 tomoz and is there any short cuts to save time to do it? Do both drive shafts have to be disconnected? Or can they stay in? Is there enough room without removing them?
    Is there anything else that could stay on that does not need to be disconnected? Or is there any points to help me do this? Is it worth doingflywheel? Got a single solid conversion flywheel but if I can get away with not changing it then I’d like to leave dual in there, would appreciate any help with this matter?
    Last edited by <tuffty/>; 20th June 2012 at 08:05. Reason: Made readable... No caps please... No double posts
    Dec 2011
    the drive shafts definatley have to come off the box needs to come off aswell i personally did this a few weeks ago i had to unbolt the drivers side driveshaft cup (the part that the drive shaft actualy bolts onto) its held in with one allen bolt iirc and then we didnt have much trouble after that
    Jan 2012
    41
    do you mean the garbox end where the spline bolts are or hub end? so you only disconnected drivers or both? im trying to save time mate as got to do it in a afternoon in about 5 hours
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    Jan 2012
    41
    thank you mate i appreciate it
    Jan 2012
    41
    tha doesnt help me thought it was a online manual but it isnt im in middle of doing it now just wanted some help from some of you as thought i would get some advice
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,024
    Ah, with you... removing a gearbox is a fairly straight forward mechanical job...
    Basics are.... Disconnect the battery, pop off the gearchange cable ends and unbolt the gearlinkage from the gearbox case, unbolt anything else that is connected to the gear box like the cable to the starter and starter motor itself... unplug the speedo sender wiring, undo the clutch slave cylinder, undo the ball joints to the hub carrier and then undo the bolts holding the driveshafts to the gearbox flanges... this allows them to be pulled away from the box, support the engine from a jack underneath or an engine support hoist...
    Remove box...
    <tuffty/>
    Jan 2012
    41
    thank you mate is there enough room o change flywheeel too?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    with the box out yes
  1. ko3s turbo upgrade agu, HELP PLEASE
    By Steve Wilson in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th February 2012, 18:44
  2. What clutch to get... replace the flywheel or not.. help!!
    By Ryan360 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th March 2011, 19:02
  3. A3 1.8t Agu help needed
    By lefterisa in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th September 2009, 07:13
  4. 1998 S4 warm starting problem? HELP!
    By myfirsts4 in forum General Technical / How To
    Last Post: 15th July 2007, 11:19
  5. 1998 AGU Turbo Intake Pipe; Help?
    By Tallpaul in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th June 2006, 10:39
