Chris NottSky Insurance
    Staffordshire
    194
    Help!! Noise has returned.
    Please could anyone advise me on whats causing this to happen.
    Its a nice sounding fluttering noise after boost when the air is dumped but my local vw specialist say its the sound of air going back through the turbo. (which is bad) ...
    i replaced the standard dv with a 007 recirculating forge which seemed to stop tho noise. Now a month later, its back. Im going to get it plugged in tomorrow to see what codes are coming up.
    I thought these forge dump valves were bomb proof.
    I had a mate in the car this afternoon, i tryed to show him the sound but it seemed fine untill it had warmed up then it came back. Now after a good run about all afternoon. Iv lost boost. Very flat! And the battery light comes on if i put foot down. Weather the two are conected. I dont know...
    Thanks in advance
    Paul
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,635
    Visit s3 Hoggy's Instagram Channel
    First thing I'd do is check all hoses going to the dv I had an issue which sounds the same. On mine the vacum hose that goes directly into the top of the dv had a split in it
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
    Staffordshire
    194
    Cheers hoggy. I'll have a look at them.
    iv just been told about the springs inside the dv. Greens for standard and yellows for tuned. Iv got a yellow one on the way so while im changing that, i'll check the pipes properly
  1. Rust on my roof rails has returned!
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th August 2013, 21:20
  2. help, key has died!
    By jcb in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd July 2011, 10:02
  3. HELP NOISE
    By hoban81 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd November 2010, 16:10
  4. Please Help - Car has a cough !
    By mr_sjc in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th September 2005, 01:13
  5. Replies: 17
    Last Post: 15th April 2005, 10:58
