Chris NottAH Fabrications
Results 1 to 15 of 15
    May 2012
    Manchester
    229
    Wonder why my sound system is garbage!
    Ive been wondering why only my front speakers work if if there is supposed to be a sub then where is the small amount of bass?
    Only got the car last week so still learning my way around it, i pulled the passenger side boot...ermmm thing off to reveal a sub and a load of unattached wires which looks like have been disconnected from an amp.
    Where is the amp supposed to be? im guessing the amp powers the rear speakers too hence why there not working, only thing is the wires look aftermarket and say fli on them, any ideas?
    its the symphony if that helps
    225
    Amp is built in to the sub.it powers the sub itself and rear speakers,it's a non fault on them so sounds like it might have failed and someone made a half arsed attempt at fixing it or trying to by pass it.
    [Dave B]'s Avatar
    Rrrrrrrr-tech
    Manchester
    1,988
    Either that or someone has had a big badass boomin FLI system in there!
    > S3 225 (03) - OEM+
    > 205 GTI (90) - Limited Edition Miami Blue with full leather - 1 of only 300 made
    > Clio v6 255 (05) - Lethal Weapon
    View: My S3 diary
    May 2012
    Manchester
    229
    got the sub and amp out and theres no visable signs of it failing, the guy i bought it off said it worked intermittently so was hoping for a loose connection somewhere but all seems fine are there any electrical wiring diagrams on here? mabie i can bypass the rear amp and run the speakers off the headunit for a little bit more sound.
    Maz
    Maz's Avatar
    Moon is made of green cheese
    Jan 2005
    East
    1,008
    Pm andymac mate he's the resident sound man on here and should be able to guide you.
    Mineral Grey [
    AMK
    James TQ's Avatar
    Apr 2012
    Essex
    548
    If the amps built in... In my a3 Quattro there an amp in the opposite side boot panel? Was it possible that the previous owner had a aftermarket stereo and just quickly installed the original for the sale?
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,395
    I've got the 6cd Bose in my s3 and it's rubbish too yet all the speakers work as I've switched balance and fader front, rear, left, right......
    Jun 2003
    World of my own
    9,813
    Just buy a replacement sub off ebay they go for about £20. You can't rewire the rears to the HU as no stock Audi HU's have an output for rear speakers.
    Is the wiring to the sub intact? or has it been butchered?
    Alex Turner
    May 2012
    Manchester
    229
    all the wiring is looks fine, there just seems to be additional wiring, I will get a multimeter on it to see if its still connected or if its been butchered behind the headunit for the aftermarket system. Will it definately be the sub then and not the amp? cheers
    Jun 2003
    World of my own
    9,813
    The amp is inside the sub. If they've tapped into the wiring and it's been left connected then it could have shorted as there is a permanent live on that loom and also the speaker outputs for the rears which would easily destroy the amp if they shorted on the chassis or each other.
    Alex Turner
    May 2012
    Manchester
    229
    The aftermarker wiring that has been put in it isnt tapped into the origianal wiring well as far as i can see in the boot anyway.
    All the connectors was taped up so i dont think anything would have shorted. Whats the best ways of testing each with a multimeter? thanks
    Jun 2003
    World of my own
    9,813
    If the wiring is intact chances are they just haven't connected it at the HU, maybe had an aftermarket HU before and they just quickly put the original back in. Easiest way to check is get a 12v testing screwdriver or multimeter and check the red plug is getting permanent live and 12v on the remote on wire when the HU is turned on.
    James TQ - you have the Bose system which is why you have another amp in the drivers side
    Alex Turner
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,395
    I have a question, my s3 has the Bose 6 cd in dash jobby and it is seriously rubbish! Is there something wrong with mine or just me expecting too much from an old car........
    Just to add I have checked all speakers working by switching balance, fader, left, right front rear ect ect.
    Cheers, Sean
    May 2012
    Manchester
    229
    cheers Andy, much appreciated
    Jun 2003
    World of my own
    9,813
    No the Bose system is particularly shyte in the 8L A3. Really woolly rumbly bass
    Are you sure someone hasn't swapped the speakers out at some point?
    You can improve it by disconnecting the earth to the Bose pin on the back of the HU, this gives you back a lot more control of the bass & treble, or upgrade the sub which has a dramatic effect.
    Alex Turner
  1. A4 Sound system
    By imported_Scunny in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th September 2004, 09:26
  2. Audi Symphony sound system
    By imported_Gytha in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th August 2004, 19:45
  3. A3 Sound Systems
    By imported_tobycruse in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd July 2004, 00:05
  4. Audi S4 sound system
    By duane in forum A4/S4 forum(B5 Chassis)
    Last Post: 28th May 2004, 17:06
  5. Upgrading sound system on A3
    By zachogbourne in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th February 2004, 17:59
