EM TuningMonster Motorsport
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By Paddya3turbo
Thread: No oil level sensor in sump agu
    May 2012
    103
    How is this possible ??? It's just blank where it's supposed to go ??? And there's no plug anywhere that would go to it ???
    This explains my low oil pressure warning on the clocks lol
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,594
    There is no level sensor on an AGU IIRC... the oil pressure is done from the pressure switch on the oil filter housing..
    <tuffty/>
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,374
    Yup, as above. No level sensor on AGU. Only pressure.
    As a result, any dashboard oil warning on an agu is pressure.
    If you're driving around with an oil pressure warning, chances are its ****ed!
    May 2012
    103
    No it's not on while driving mate , only when key is turned to on after a minute it comes on but as soon as car is started it disappears ??
    May 2012
    103
    Just had my downpipe and exhaust put on and it sounds great , deffo feels more responsive with the tip fitted aswell , dare I say slightly faster lol !! Got my new thermostat fitted aswell and all for £30 with new coolant
    deeman88 likes this.
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,374
    hmmmmmmmmmmmmm. Strange.
    As long as it's not coming on whilst driving then that's good.
    Did you sort the gearbox issue?
    May 2012
    103
    Yeah mate ! There was nothing wrong with it lol ! A dodgy bit of metal that supports the filter had come loose and was stopping me engaging the 2 gears ! After a bit of rattling it came loose lol
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    I had the sump replaced on my old A3 1.8T by a garage and they put a sump with an oil sensor in it because it was all they could source at the time.
    They replaced the oil pickup at the same time.
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
  1. Oil level sensor problem ?
    By luis.filipe in forum Audi S4/A4/A4 Cab (B8 Chassis)
    Last Post: 22nd April 2011, 22:32
  2. Oil level sensor
    By ianysm in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st January 2010, 22:14
  3. Sump oil level sensor conversion
    By lucksta in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th April 2009, 20:46
  4. Oil Level Sensor on Early S3's?
    By metricspaces in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th February 2009, 16:08
  5. Replies: 1
    Last Post: 17th August 2007, 23:10
