Monster MotorsportVolks Autos
Results 1 to 8 of 8
    Jun 2012
    6
    S3 8l Haldex problem
    Hi Everyone,
    New here,my 2nd post is a problem already!
    Getting wheel spin so no 4wd!.So far I've checked,
    the haldex fuse,earth strap underneath car from differential to body,
    handbrake switch working correctly
    .7 amp draw on VCDS measuring blocks to the controller,
    cleaned the connection at the controller,
    scanned with no faults and is communicating with the haldex controller,
    in output tests pump is making noise,
    I didnt hear any noise for the test to engage clutch but not sure should this make noise anyway? When the car is on a lift the 4 wheels are spinning but defintely not working when on the road?
    The haldex oil and filter were last changed about 18months ago or 10k.
    Everything looks ok to me and no funny noises either?
    Im not sure where to go from here so I would be greatful if anyone had some more suggestions!
    Also Ive searched through other threads with the same problem too,
    Dave
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    If you've got access to ramps it'll only cost £15 to drop the oil and put some new stuff in so that can't be a bad place to start, at least then you'll know 100% it has the right amount in.
    If the precharge pump is a little bit fubar, will it still make a noise? might not be making enough pressure to engage the haldex clutch for power delivery on the road?
    Take the precharge pump out and inspect it?
    EDIT: I forgot to say, pull the Haldex fuse and see if it handles/responds in the same way. Also have you tried driving it with the ESP off?
    S3 AMK 2002. Only 203 BHP left in my poor little engine, currently searching for the 7 missing horses.
    Mods: Powerflex bushes at the front and rear, 710P DV, ambient light module, Badger5 V3 TIP, S2000 Filter.
    Jun 2012
    6
    Thanks for the reply,
    Yes changing the oil would be a good place to start,at least it can be ruled out!
    I never tried driving the car with the fuse out,If I turn off traction control the front wheels only spin,I had my girlfriend doing fast take off's on the grass just to make sure!
    Pump not making enough pressure could be a cause alright,I'll have a look at it tonight,
    Cheers will report back with more news
    Dave
    Jun 2012
    6
    Its been awhile since i have tried to sort this out!
    I have since changed oil and filter in haldex but the problem still persists.I was reading on another thread about 5% going to the rear but not too sure what this means!
    Im thinking now maybe the pump is not making enough pressure like vfr800 said to engage the clutch? Ive since had the car remapped so I need to sort this out now!
    Any suggestions greatly appreciated.
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Quote Originally Posted by Bullseye View Post
    I've been thinking about this. If the pump isn't make enough/consistent pressure then it might be slipping the haldex clutch - more than it's designed to be - which might be a cause of the plates burning out/seizing.
    You mean 50%? When the haldex clutch is fully engaged it will transfer all the energy sent down the prop shaft to the rear diff. So when it's fully engaged you'll be getting a 50/50 split of power between the front and rear. I don't know if the haldex is designed to reduce the power to the rear by slipping the haldex intentionally - any way not for sustained periods I'd have thought.
    (btw these are my assumptions/thoughts so I could be entirely wrong)
    Liam
    Jun 2012
    6
    Quote Originally Posted by vfr800 View Post
    Liam
    Thanks for your reply Liam,
    I think I might take the pump off and get it reconditioned to rule that out but as you said the harm could be already done to the clutch plates.Is it possible to repair/replace these?,the local dealer is 1500 euro for new haldex with my one part exchange.I have been looking for second hand one but Im in ireland and not that many in the breakers at all!Its puzzling me because when i have it on the lift I tried stopping the rear wheels when I had the car going but there was fair pressure on them and they were still spinning,but on wet grass they still wouldnt spin!
    vfr800's Avatar
    Feb 2012
    Melting Beans
    740
    Yeah you can get new haldex clutch plates - but it'd probably be cheaper to drive over here and get an old one from from a scrappie. Loads of different VAG models use the same Haldex clutch.
    I guess a new(er) haldex pump is your best bet for the moment. A new one will be warrantied for two years as well. I bet a recon one won't.
    When you change your haldex oil - look to see how much debris/gold coloured flakes - that's your friction surface on the clutch plates I believe.
    Liam
    Jun 2012
    6
    Thanks for your help!
    I seen this on ebay motor for haldex pre charge pump gen1 | eBay
    When I changed the oil it was clean but on the filter there was half a teaspoon of grey slime but no flakes of any description!Im constantly checking for fault codes too but none so far.Ichange that pump and report back with news hopefully good!
  1. S3 Haldex problem
    By sportquattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2012, 08:31
  2. Strange haldex problem?
    By quattro1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th February 2011, 22:07
  3. Haldex problems on Dyno
    By Shane. in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd October 2010, 23:50
  4. Haldex problem
    By edward_harris in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st May 2008, 16:48
  5. Haldex Problem (i think!)
    By Wicked666 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th November 2006, 16:40
