Monster MotorsportChris Nott
Results 1 to 14 of 14
    MrTackalakalaka's Avatar
    Jan 2012
    Truro, Cornwall
    426
    Powerflex Bush kit
    Hi there everyone
    I am thinking of buying a full powerflex bush kit for my S3.
    Im getting some coilovers fitted next week and I'm thinking it might be worth getting the full power flex kit fitted as well whilst the suspension is being done.
    I know there is a bit of movement in the suspension but not sure what bushes need replacing. And I know power flex don't do top mount bushes which i think need doing but if i get the kit are all the other bushes there that i may need to replace?
    The bushes included in the kit are:
    2x FRONT WISHBONE FRONT BUSH
    2x FRONT WISHBONE REAR BUSH
    2x FRONT ANTI ROLL BAR MOUNT
    2x REAR WISHBONE FRONT MOUNTING BUSH
    4x REAR WISHBONE INNER BUSH
    2x REAR ANTI ROLL BAR MOUNT
    1x STEERING RACK MOUNT
    1x FRONT ENGINE DOG BONE
    Scott
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    Email andrew@ald on here and ask him for a set of defcon style bushes for the frot wishbone arm, in reduces the 45mm bush down to 30mm and really tightens the front up, also some people dont like to poly bush the rear wishbone mount as they can pop etc, instead look to use tt solid bushes, cheaper and effective.
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    Also if you can afford it id chuck in a set of daves rear tie arms.
    Jan 2012
    Truro, Cornwall
    426
    Thankyou for that!! Says in the description the facelifts have a 45mm on the front wishbone and the pre facelifts have 30mm on the front wishbone. Mine is a pre facelift so should i just get that anyway?
    Will have a look at the TT bushes!
    Thanks again for the info
    ZAS
    Jun 2012
    64
    Oh bugger, I'm in the process of getting my bushes sorted as well and ordered the 45mm bush and rear wishbone front mounts; I heard that the control arms bushes etc. cause the squeaks and ended up not buying them, so hope I haven't cocked up.
    Dani, have a link or anything which shows what those 30mm bushes look like?
    JB
    bengal's Avatar
    Eskiv Champion
    Sep 2010
    Staffordshire
    537
    Psi tuning sell poly bush top mounts, they're not made by powerflex but are still good no doubt.
    PolyBush Polyurethane Top Mounts (Pair) - Golf Mk4 etc + Lupo/Polo 6N/2 > Suspension > Golf Mk4 1998-2004 > VW Golf > VAG Specialists > PSI Tuning - VAG Specialists
    Edit: The S3 isn't listed for fitment but I'm pretty sure they're the same as the A3 in this respect. It's worth contacting them to find out.
    Jan 2012
    Truro, Cornwall
    426
    Thanks man! That's really helpful!! I shall get in contact with them!
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,173
    No links, type defcon bushes into ebay.
    Tak- i bought new wishbones and had the defcon bushes welded in only to find that i had 30mm wishbones, they are super rare as audi ordered a recall to destroy them, i ended up selling them for £200 on ed38 haha, paid for all my bushes and my new wishbones. So moral is check then huy lol.
    Sep 2011
    69
    you will want to look at subframe bushings / interfaces too...
    any of you guys tried rigid collars?
    Rigid Collar.com - Subframe Rigid Collar Kit - Improve your Vehicles Handling - Honda | Nissan | Toyota | Mitsubishi | BMW | Volkswagen
    damo.h's Avatar
    DVLA Say it's Black
    NW
    3,608
    dani unfortunately these are now a myth. I have the last of Daves tie arm production.
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,455
    Quote Originally Posted by olly quattro View Post
    i like these alot. il be getting 4 of these. thanks
    edit. just seen the price. are they having a ****ing laugh!!!?
    dave. help?
    Jan 2012
    Truro, Cornwall
    426
    Right I'm ordering my coil overs this morning.
    Might get a bush kit as well. How do you know if you need a 30mm wishbone bush or a 45 mm wishbone bush?
    Mine is a prefacelift
    on the ebay listing it says that earlier models have 30mm bushes on the front wishbone?
    ZAS
    Jun 2012
    64
    I just went with what PowerFlex posted on their site, which is exactly what you quoted from ebay; pre-facelift has 30mm spacers...
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    7,455
    Quote Originally Posted by MrTackalakalaka View Post
    even prefacelifts can have 45mm bushes. so check.
    pretty big size difference tbh, you should be able to see. just get a ruler out
  1. Anyone here running a *full* Powerflex bush kit?
    By mwstewart in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th July 2007, 11:28
  2. Powerflex Bushes
    By johnie72 in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th May 2007, 21:23
  3. Rear Camber Problem Adjustable bush kit!!!
    By 242spot in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th December 2006, 21:31
  4. Powerflex bushes
    By robthehungrymonkey in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th November 2005, 10:07
  5. powerflex bushes
    By imported_velcrobix in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th November 2004, 13:07
