Results 1 to 13 of 13
    Sep 2005
    Bucks, UK
    27
    S3 225 idle speed?
    Hi,
    I have just bought a 2002 s3, and am wondering about the idle speed..
    At the minute, she's idling at about 1.5k when warm, which i reckon is a little high - even if the climate is on and working overtime at the minute. I dont think it is the climate tho, as my old A4 used to return to about 900 after the climate kicked in...
    Cheers guys,
    Rob.
    Feb 2004
    331
    Re: S3 225 idle speed?
    Sounds high to me .. I have T-Sport so it may be different to mine which is about the 900 mark.
    Jun 2003
    Hythe, Kent
    1,180
    It is high, I've owned a few Audi, always idle on the 800/900 mark.
    Kev.
    Nov 2003
    England
    38
    Thats really high... My S3 idle's between 800/900 as normal... only slightly more on the initial choke time when cold...
    Get it checked...
    Wiz
    Oct 2004
    13
    Sounds very strange.... I have a 2003 S3 (225) and it always idles at 800 (even work the aircon pumping!)
    RacingTeatray's Avatar
    Freezing in Moscow
    Oct 2004
    Moscow
    244
    Yes my 52-plate S3 225 idles at 800rpm. It idles at about 1250rpm when first turned on from cold but even then only very briefly.
    The CC doesn't make an appreciable difference that I can detect.
    imported_monkeytrousers
    Mine too - approx 800.
    Sep 2005
    Bucks, UK
    27
    oki, thanks guys [img]/ubbthreads/images/graemlins/smile.gif[/img] looks like its time to call the dealers..
    Jun 2003
    Hythe, Kent
    1,180
    Let us know how you get on.
    Kev.
    Sep 2005
    Bucks, UK
    27
    Okay, she went into the dealers this morning... see what they have to say.
    In the meantime. they've given me a 05 2.0T FSI DSG a3 to play with... [img]/ubbthreads/images/graemlins/woohoo.gif[/img]
    this cars good fun! The first time i tried to pull away sharpish though, it revved the balls off the engine and dumped the clutch! Several yards of wheelspin later and a boy-racer scowl off most of the people around me (it was ruch hour), traction was regained... [img]/ubbthreads/images/graemlins/angel.gif[/img]
    Sep 2005
    Bucks, UK
    27
    aaaand theyve found another fault.... another part needed.....
    Nov 2004
    21
    I think I have the same problem, so if you explain what was the fault detailed , it will be greatly appreciated
    Sep 2005
    Bucks, UK
    27
    okay, car back now and fixed. It feels like a new car again..
    to summarise:
    symptoms:
    High Idle - around 1400-2000 rpm (turbo sometimes spins up on idle)
    Surging whilst pulling away gently (turbo would spin, then stop)
    Feeling of the car driving itself (not good in 30mph zones)
    Lack of engine power
    Hesitation
    and in latter stages, engine check light came on (although not for 2 weeks)
    Resolution:
    replaced lambda sensor
    replaced throttle pedal potentiometer
