EM TuningSky Insurance
    Jul 2005
    Kent
    29
    Changing over Instrument cluster
    I've given up on my instrument cluster - (only works when its warm) so I've sourced a second hand one from a scrappy which has the same model number etc..
    I called HR Owen Audi in Nth London and they've said that they will not even attempt to fit it. By fitting I mean recoding the immobiliser using the time sensitive code from Audi-Germany.
    Does anyone know of a more enlightened dealer in the South East who will?
    Carlos
    imported_nadger
    Re: Changing over Instrument cluster
    what years your car, the immobiliser coding is stored in an eeprom on some pcb's and this should be easily overcome, but on the newer type itsstored in a micro, this is the problem one. open them up and take a piccy for us to view
    Jul 2005
    Kent
    29
    Hi,
    Its a 2001 Audi A3 PD130 with the Jaeger/Magentti Marelli cluster. I will try and get a few pics... also if anyone knows of a cluster repairer anywhere in the UK, I would be very grateful. There are hundreds of them in the USA, but I can't find a single one here.
    Carlos
    Khufu's Avatar
    West coast of Scotland
    5,693
    they sound like a bunch of useless gits. I'd imagine even though they didnt supply the part they would happily charge you to fit it.
    imported_nadger
    there's a place near manchester called camco88, i used them a few years ago to fix a G60 ecu, im pretty sure they do instrument repairs too. google should find them m8.
