EM TuningVolks Autos
Results 1 to 15 of 15
    Jun 2012
    Torqauy
    100
    Remove&refit of a k03 turbo help!!
    Hey guys iv got a second hand k03 coming next wk and me and my mecanic mate are gunna try and fit it, could some1 be kind enuf and write me up a little guide on what to do and what needs to be taking of etc id be really greatfull many thanks!!
    May 2012
    Norfolk
    118
    In all farenes if you mate is a mechanic surely he knows how to change a turbo ?
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    Undo the 3 turbo/mani bolts, take the exhaust manifold off and all will be revealed... the coolant pipe that goes around the back of the engine under the ex mani just needs moving down a tad to get to the stud nuts (cyl 1 and 2)... the rest should be fairly easy to work out...
    Undo the downpipe from under the car...
    <tuffty/>
    Paradox1's Avatar
    Aug 2011
    SoUf EaSt,Uk
    1,829
    Google ko3 swap to ko3s and it should come up with a very detailed guide of how its done with all the gaskets, etc needed.think its on ukmkivs
    Word!!!
    My A3/Martys Golf would smash that, and this guys £7000 GT9743 supercharged love machine.
    Jun 2012
    Torqauy
    100
    As always tuffty thank you fella, and marty my mate is a tyre fitter but only does minor work at his place.
    Jun 2012
    Torqauy
    100
    Iv read its 3 bolt job but on the turbo im getting theres 4 long threads is this rite? And what gaskets do i need as i cant seem to find what or how many i need im using my fone and signal crap so just easier to post here. Thanks
    May 2012
    Norfolk
    118
    you will need turbo to manifold gasket and turbo to downpipe gasket.
    Make sure before you fit new turbo you use a syringe and push some oil into the oil feed on the turbo also worth replacing the engine oil and filter at the same time. Me personally always unplug the injectors when its done and turn it over to make sure the oil gets round properly and then connect injectors and fire it up. However you will need diagnostics to clear the open circuit codes for the injectors
    Hope that helps
    Jun 2012
    Torqauy
    100
    Are these gaskets only from main dealer as i cant find them on ebay.
    May 2012
    Norfolk
    118
    Get the proper ones from dealer the cheap ones normally break down and end up blowing
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,389
    gasket from main dealer yes. you also need oil and water crush washers. Google ko3S swap and there's a massive how to guide on UK MKIVS by a member called NooNoo.
    I've never needed to remove a manifold to do it in the past though. Comes out easily enough without
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,621
    With the manifold off you can easily get to the oil and water hoses on top... just easier... why make more work for yourself
    Can have one off in less than an hour...
    <tuffty/>
    Jun 2012
    Torqauy
    100
    Is it 3 or 4 bolts? Coz the1 im buying has 4 long threads with the hole in middle of them!! What the hell is oil and water crushers lol?
    May 2012
    Norfolk
    118
    google banjo bolt washers you will see
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,389
    3 bolts is the exhaust manifold side, 4 bolts is the downpipe side.
    It's just the other way up in pictures.
    Jun 2012
    Torqauy
    100
    Oh ok nice1
  1. Audi S3 speedo removed and refitted now will not start HELP PLEASE
    By jacks3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2014, 01:18
  2. The facts about the K03 Turbo!
    By Gambba in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th March 2014, 14:00
  3. Turbo help with k03s
    By jamesa3t in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th May 2012, 17:48
  4. is it possible for a k03s turbo to be...
    By Backdrifts in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th January 2007, 21:39
  5. The facts about the K03 Turbo!
    Last Post: 14th May 2004, 15:37
