Hey guys iv got a second hand k03 coming next wk and me and my mecanic mate are gunna try and fit it, could some1 be kind enuf and write me up a little guide on what to do and what needs to be taking of etc id be really greatfull many thanks!!
Undo the 3 turbo/mani bolts, take the exhaust manifold off and all will be revealed... the coolant pipe that goes around the back of the engine under the ex mani just needs moving down a tad to get to the stud nuts (cyl 1 and 2)... the rest should be fairly easy to work out...
Iv read its 3 bolt job but on the turbo im getting theres 4 long threads is this rite? And what gaskets do i need as i cant seem to find what or how many i need im using my fone and signal crap so just easier to post here. Thanks
you will need turbo to manifold gasket and turbo to downpipe gasket.
Make sure before you fit new turbo you use a syringe and push some oil into the oil feed on the turbo also worth replacing the engine oil and filter at the same time. Me personally always unplug the injectors when its done and turn it over to make sure the oil gets round properly and then connect injectors and fire it up. However you will need diagnostics to clear the open circuit codes for the injectors
gasket from main dealer yes. you also need oil and water crush washers. Google ko3S swap and there's a massive how to guide on UK MKIVS by a member called NooNoo.
I've never needed to remove a manifold to do it in the past though. Comes out easily enough without
