JMB RetrofitsEM Tuning
Results 1 to 31 of 31
Like Tree1Likes
  • 1 Post By <tuffty/>
Thread: forge 007p or 008p?
    tonks s3's Avatar
    May 2012
    33
    forge 007p or 008p?
    I realize the 008 is a newer version is there much of a difference in performance? Or just a different design?
    Cheers :-)
    liquids3's Avatar
    Jul 2010
    Bristol
    933
    007p is great,not alot of difference between the two,i think the design to remove replace the spring choice is better on 008,and same with any redeveloped product,there will be bits they redesign for a reason.so i would recomend 008.
    Audi S3- 1.8T Quattro
    Liquid Yellow
    Audi R8 Rims
    Its never finished!
    rhubarb4's Avatar
    Certified Jardo Slayer
    Mar 2008
    Midlands
    1,715
    007PA for me I much prefer the adjustable boost pipe entry.
    <img src=http://cdn.as-static.com/vb/images/smilies/scared2.gif border=0 alt= title=Scared2 class=inlineimg />
    i wear ladies underwear to work.
    tonks s3's Avatar
    May 2012
    33
    Cheers guys think I'll go for the 008 its only £10 more alsoy S3 is standard at the moment but am going to map it soon to hopefully to 270 which spring should I put in? Sorry for my ignorance I'm new to this :-)
    Dani_B19's Avatar
    Nov 2008
    Barnsley
    7,222
    Yellow spring mate, even on standard map.
    tonks s3's Avatar
    May 2012
    33
    Cool cheers mate :-)
    tonks s3's Avatar
    May 2012
    33
    I'm running a splitter r atm would it be ok to get the remap with that and then swap over once the 008 comes? Or will I get more bhp with the 008 on remap? Cheers
    Suck.Squeeze.Bang.Blow
    Jul 2011
    Madchester
    228
    You should be fine on the yellow spring once remapped as I've recently learnt, there is a forge outlet on eBay and you can get a full spring and shims set for £22 delivered
    tonks s3's Avatar
    May 2012
    33
    Cool thanks guys! :-)
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,453
    008 comes with a spring kit, shims and a Forge keyring IIRC...
    <tuffty/>
    Benjiman46 likes this.
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    <tuffty/>
    Yes it does. I got one about 3 months ago. Standard map & I have the yellow spring fitted. It comes with 3 or 4 shims, the forge keyring and 3 springs to choose from; a green (weak), yellow (medium) and blue (strong) and also an allen key for the lid.
    It will come with the green spring fitted, I swapped it straight away for the yellow, and then swapped back when someone told me it's very bad for the turbo to have a yellow spring fitted on a standard map, and it ran like crap, so I put the yellow spring back in and never looked back.
    IMO the 008 is the better of the 2 because it's so much easier to swap the springs and it looks awesome! I always thought the 007p looked a bit cheap (sorry 007p fans! lol)
    Hope this helps
    Ben
    1.8 litre porsche eater!
    R-Tech Terrorist Squad - 265bhp & 275lbft
    Bean5's Avatar
    kidney bean
    Jan 2012
    stafford
    334
    i was thinking of geting 008p for my b6 a4 1.8t but then heard that messing with the turbo system this way can f**k the car up in a bad way! is this true??
    Next Steps. (wanted)
    s`line steering wheel
    oem interior mods
    milltek exhaust system..
    window tints.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,453
    Fitting a Forge 007/008 won't harm anything if fitted properly... not having a working dump valve is what will potentially break a turbo and using a atmospheric style valve like a Split-R or BOV leads to running issues on Bosch managment
    <tuffty/>
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,285
    As mentioned the 008 comes with different springs and a fitting kit so a worth while choice in my opinion.
    Damian @ DPM Performance
    DPM Performance
    W: www.dpmperformance.co.uk
    T: 01207 561606
    E: sales@dpmperformance.co.uk
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    Quote Originally Posted by Bean5 View Post
    As <tuffty/> says, this is not true. Whoever told you that needs to learn more about engines and turbos. The standard Bosch DV (diverter valve) has a tendency to break, especially when a car is remapped.
    A forge 007p or 008 DV is also a much more efficient design, where a spring and piston is used, apposed to the standard Bosch DV that uses a diaphragm. The efficiency of a DV is it's ability to dump all the pressure that is in the turbo system, into the intake (or to atmosphere in the case of a dump valve or Blow Off Valve) when the throttle is released.
    This stops the boost pressure from backing up in the system, when the throttle body butterfly valve is closed, thus stopping compressor stall, which in extreme circumstances, can snap the turbo shaft.
    This compressor stall (or turbo flutter) is what a lot of people hear on throttle release, when they remap their cars with standard DVs still fitted. Because the standard DV simply cannot get rid of all the excess boost from the increased pressures a remap gives.
    The other side of standard DV failure is that the crappy rubber diaphragm splits and leaks precious boost! Something that alot of the time goes un-noticed until someone fits an aftermarket DV and wonder why their car is so much faster!
    The moral of the story then so to speak, is buy one
    Damian @ DPM Performance has them at a good price
    Hope this helps
    Ben
    Bean5's Avatar
    kidney bean
    Jan 2012
    stafford
    334
    yer cheers benjiman, i wont "quote" you as dont want to clog up the thread with big quotes lol, but yes that difinatly helped, i have seen they are a cheap item to buy but like you say "fitted correctly" their great, i wouldnt know where to start, how much would this be fitted? any ideas?
    also one more question, would there be any change in sound once fitted?
    thanks
    oem interior mods
    window tints.
    May 2012
    12
    is the yellow spring 15-23 psi?
    Jun 2012
    West Sussex
    24
    Standard a3 1.8t 150bhp yellow spring?
    DPM
    DPM's Avatar
    Jun 2006
    Newcastle/Durham
    4,285
    Quote Originally Posted by Black-Hat View Post
    No you'll need a green spring.
    DPM Performance
    T: 01207 561606
    Jun 2012
    West Sussex
    24
    Quote Originally Posted by DPM View Post
    Benjiman46's Avatar
    R-Tech Terrorist
    Feb 2012
    Worksop
    547
    Quote Originally Posted by Jezzas3s View Post
    Forge Motorsport | Alloy Fabrication
    Just incase that doesn't work, the ratings are;
    Valve Spring color coding
    Green - 5-15 PSI
    Yellow - 15-23 PSI
    Blue - 23-30 PSI
    Red - 30 + PSI
    l6rth's Avatar
    Mar 2011
    Cambridge, Cambridgeshire, United Kingdom
    85
    Hi, not been on for a while, how hard is it to fit one of these valves on an 8p? Thinking f doing this and green panel filter per re map
    Rob
    L6rth
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,453
    Quote Originally Posted by l6rth View Post
    Rob
    Different valve altogether for a TFSI on an 8P
    <tuffty/>
    l6rth's Avatar
    Mar 2011
    85
    Thanks for that tuffty, I was about to buy one, what do I need?
    L6rth
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,453
    Don't normally replace them as the Forge one is quite expensive... think its this one
    <tuffty/>
    l6rth's Avatar
    Mar 2011
    85
    I know it's expensive but if I'm going to re map I should do this first right? I'm only going stage 1 or is the standard one good enough?
    L6rth
  28. #27
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,453
    Not personally seen a std one go as yet but tend to see more 20v's than TFSI's when I am at Bill's so can't really answer with any authority I'm afraid... I'd ask on the 8P forum as they should be able to guide you a bit better than me
    <tuffty/>
  29. #28
    l6rth's Avatar
    Mar 2011
    85
    Ok, thanks for your help.
    L6rth
  30. #29
    Oct 2011
    759
    Read about the mad max diverter before you buy forge.
    linky VWVortex.com - The Madmax Diverter Valve is better then your diverter valve!!!
  31. #30
    Nov 2010
    Newmarket, Suffolk
    71
    I just picked up a 008 from Forge at the Autosport International show today at the NEC Birmingham .... best show I've been to btw ....
    Anyway, What are the shims for??
  32. #31
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,453
    Quote Originally Posted by AFDanHef View Post
    Altering the spring tension... don't worry about it as all you will need is the green spring... not looked at the 008 internally yet but the 007p's need a shim to cut down the piston volume so they react better... 008 is shallower so may not need it..
    <tuffty/>
  1. forge 007p
    By kevsn in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2008, 11:04
  2. Forge 007p
    By Jay in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd August 2008, 10:25
  3. Replies: 0
    Last Post: 3rd March 2008, 12:10
  4. fitting forge 007p is it much of a job to fit??
    By Craigybaby37_A3quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th November 2007, 13:12
  5. Fitting a Forge 007p?!
    By Cossie_boy in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st August 2007, 20:34
