AH FabricationsBadger5
Results 1 to 7 of 7
    Sep 2005
    uk
    Front Mount Intercooler
    Can anyone tell me what a Front Mount Intercooler will give me ??
    Ta
    Ess_Three's Avatar
    Feb 2001
    Aberdeenshire
    5,385
    Re: Front Mount Intercooler
    ...an enormous sense of wellbeing?
    A FMIC wont give you anything by way of power.
    It will however, stop the engine loosing the power it is capable of making by cooling the inlet charge better on warm days, resisting heatsoak better etc.
    But a FMIC wont add power.
    imported_bmx
    you will more than likely see about 10 bhp on a dyno when you put a fmic on. but like ess-three says its because you have recovered lost bhp due to heat soak. well worth doing though. also try the cold side diverter conversion, it cuts down the turbo lag feel a bit, makes it smoother back on the power after each change,
    on this matter, I have been experiencing what is probably lag. If I am "on cam" and "drop the hammer" it picks up a second or 2 later with a real thud. This is recent and hasn't been behaving like this before, it so sudden and aggresive like someone has booted the car forward. It used to be more progressive and probably faster, is this a side effect of the hot weather or something i need to be watching??
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,566
    [ QUOTE ]
    [/ QUOTE ]
    Turbo lag is basically the time it takes for your turbo to spin upto speed from the moment you press the throttle, if there is a 2sec delay before the power comes in, then I should get it checked, shouldn't be more than 1 sec delay, unless you are pulling 1k revs of course. I had the 2 second delay problem a while back, before I got my car remapped, turned out to be a knackered MAF, so maybe worth a look?
    Hot weather usually reduces performance a little due to heatsoak, and sometimes smoother power delivery because of it.
    Feb 2004
    UK
    1,320
    Especially helps out when running big boost from a chipped car.
    Sep 2005
    uk
    cheers chaps !
