Volks AutosJMB Retrofits
Results 1 to 21 of 21
    "StAtIk FaNtAtIk"
    May 2011
    16
    A3 8L 1.8T quattro Intercooler help
    Hi Guys,
    I have had a look for what pipes to use for this but I'm struggling a bit.
    I'm looking to get a 600x300X76 intercooler and wondered if anyone could help me out with what piping I would need?
    Thank you so much guys,
    Morty
    James TQ's Avatar
    Apr 2012
    Essex
    548
    i also need a list of pipe sizes and dimensions so if anyone has a list it could help us both : )
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Loads of FMIC info inthe stickies... for both A3's and S3's including fitting pics, parts lists and other such shizzle..
    <tuffty/>
    James TQ's Avatar
    Apr 2012
    Essex
    548
    had a look, cant find a lift of pipes and dimensions :s
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,466
    Not looking hard enough then...
    http://www.audi-sport.net/vb/a3-s3-f...ml#post1489006
    <tuffty/>
    boost-addict's Avatar
    Aug 2011
    977
    would you not be better buying a kit?
    i looked in to buying a s/h intercooler of a good make and then buy the piping but it works over quite a bit in the end
    so im going to just buy a decent intercooler kit for my model etc
    Customboy's Avatar
    Jan 2012
    SE London
    836
    Right not sure if this will help u guys hope it does, due to me having a ko4 conversion done soon I needed to change my current forge fmic setup and will need to buy a wellycooler, I can't thank nick (prawn) enough for the pipe setup he has recommended to me this is what he has recommended for me and hope this helps
    Cold side: You will need:
    1x 76-63mm 90 degree reducer in silicon
    1x 63mm 90 degree silicon bends
    1x 63mm 90 degree alloy bend
    1x 63mm straight 100mm alloy coupler.
    plus clamps to suit.
    Then for the hotside, you will need: 1x 76-63mm 90 degree reducer in silicon
    1x 63mm x 300mm straight alloy pipe
    1x 63mm 45 degree alloy bend
    1x 63mm 45 degree silicon bend
    1x 51-63mm 90 degree silicon reducer
    That is all the pipework you will need.
    eeeeeeerm, I used JCS Hi-Grip stainless.
    OD of the silicon pipes will be 73mm, I think there's a 60-80mm clamp. then on the core the OD will be 86mm, and I think there's a 70-90mm clamp
    p
    THE BLUE BEAST, TAKEN FROM ME, GONE BUT NOT FORGOTTEN
    RTECH STAGE 2 REMAP NOW RUNNING 223 BHP AND 253 FTLB OF TORQUE,
    SUBARU IMPREZA WRX ESTATE SOON TO BE RUNNING 340 BHP
    ANTI LAG/LAUNCH CONTROL/MAF LESS/ LOVE IT !!
    Customboy's Avatar
    Jan 2012
    SE London
    836
    Pic of intercooler setup once again all credit to nick (prawn)
    p
    Aug 2011
    977
    looks good, is it any particular make?
    Customboy's Avatar
    Jan 2012
    SE London
    836
    If I Remember it's a toyosport one loads on best for around £80
    p
    Customboy's Avatar
    Jan 2012
    SE London
    836
    Sorry meant to type loads on eBay for about £80 new
    p
    Aug 2011
    977
    yer been looking at the ebay kits, look good enough for what i need,
    Prawn's Avatar
    My other car is a MINI!!!!
    Dec 2006
    Basingstoke
    9,318
    follow Tuftys link, I put links up to the core and pipe sellers on ebay, and listed all parts needed for a ko3/s fitment in the thread. the list bobby has above is specifically for his ko4
    Be warned though, if you're keeping the stock A3 bumper it's tight!
    Prawn's Avatar
    Dec 2006
    Basingstoke
    9,318
    the finished article isn't too intrusive though, and if you painted it black it'd be even less so:
    James TQ's Avatar
    Apr 2012
    Essex
    548
    Thanks. Just what I needed, think I'm king to get a kit of eBay then replace the chromed 90degree elbows with black silicone ones just to dull it down abit! Thanks people.
    Aug 2011
    977
    Your best of keep hard pipes as much as possible. Just spray them with black high temp paint just so it doesn't crack or craze .
    "StAtIk FaNtAtIk"
    May 2011
    16
    This is a fantastic thread, thanks for the info guys!
    Reesy's Avatar
    East Sussex
    3,604
    The only question I have with prawns set up is that the cooler might be too big, but it depends what you plan to do with the car in the long run. I will be fitting my large collection of Fmic bits in the next few weeks, and I have gone for a smaller cooler which in turn means that the 76-63 reducers are not needed.
    Customboy's Avatar
    Jan 2012
    SE London
    836
    What turbo setup u running reesy?, the fmic setup I think is well tested and one of the best IMO cost wise, I know toyosport do the same intercooler but slightly smaller loads on eBay, but one day if u do decide like me to go for bigger power it's best to just use this setup and will work find depending on what turbo u have now, I'm running stage 2 rtech ko3s, and due to me going bigger I have to shelve my current forge setup as the pipework route is completely different to what I need
    p
    Reesy's Avatar
    East Sussex
    3,604
    I've got a 3s on mine, and have gone for the smaller toyo cooler. I think the welly cooler is too big for a stage 2 k03s, and all you really need to do to change from small cooler to welly cooler is some crash bar trimming, 76-63 reducers unless you do what karl did, and some tweaks to make the pipes fit the reducers..
    "StAtIk FaNtAtIk"
    May 2011
    16
    This has been a great help, thanks to all that have contributed!!! I'll post here when I've done, It'll take me a while as its a daily and I live in a flat!
    Thanks again!
    Morty
  1. A3 1.8T Quattro, Buying Help
    By dan-quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2008, 19:22
  2. Help buying a used Audi 06 quattro need help!
    By 9relude8 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 19th March 2008, 00:50
  3. '03 A3 3.2 Quattro headunit help please
    By mrmuscle in forum In-Car Entertainment
    Last Post: 18th October 2007, 02:07
  4. A4 2.8 Quattro Suspension help.
    By markcass in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th September 2007, 18:39
  5. Newbie Quattro Sport help!
    By ollie16v in forum A4/S4 forum(B5 Chassis)
    Last Post: 1st June 2007, 00:33
