EM TuningJMB Retrofits
    rhubarb4's Avatar
    Certified Jardo Slayer
    Mar 2008
    Midlands
    1,715
    Funny noise pulling off today any idea's
    As above I pulled off and as I drove down the road a funny grindy noise came from the front wheel area, sounded as if a bit of wire was wrapped round the wheel or a bolt had come loose and was rubbing. I stopped the car had a look but nothing so I rolled it forward then back could still hear it then back once more and it went, not heard it since and Iv dove about 10 miles.
    I scanned it just and it's thrown a fault code the only one there is this. 00526 - Brake Light Switch (F): Implausible Signal
    Possible Causes
    • Wiring/Connectors from/to Brake Light Switch (F) faulty
    • Brake Light Switch (F) faulty
    Possible Solutions
    • Check/Repair Wiring/Connectors from/to Brake Light Switch (F)
    • Check/Replace Brake Light Switch (F)
      • Check Measuring Value Blocks (MVB)
    Special Notes
    • FAQ 2.7. Many Automatic Transmission Control Modules will show a DTC 00526 or 17087 that indicates a faulty brake light switch. This can be ignored and will not appear if you press the brakes once before checking for Fault Codes.
    As I'm going to inters it's bugging me anyone know if it's a easy fix or do I need to do anything to be on the safe side and would this be cause the above fault of the grinding noise.
    Thanks, Chris.
    <img src=http://cdn.as-static.com/vb/images/smilies/scared2.gif border=0 alt= title=Scared2 class=inlineimg />
    i wear ladies underwear to work.
    s3 Hoggy's Avatar
    Whats going on???
    Apr 2009
    Oxford
    1,653
    Visit s3 Hoggy's Instagram Channel
    I had the same noise after I fitted my new suspension, turned out I had knocked the splash guard on to one of the discs. They're really flimsy and bendy so it just bent back. I'm not saying that's your problem but could be a possibility?
    2002 S3 REVO
    Milltek, Sachs Organic clutch, 007p, Genuine RSTT's, BBS RS2's
    Koni FSD & H&R springs, Neuspeed 22mm rear ARB, KW tie arms
    LCR Brembo's with DS2500's & Paul's 300mm Rear disc kit,
    Michelin Pilot Sport 3's,Badger5 V2.2 Jetex filter & heatshield
    rhubarb4's Avatar
    Mar 2008
    Midlands
    1,715
    I had a look but the splash guards are fine, it's really bad timing as I won't have any spare time to get it to a garage before inters, just hoping it will be ok.
  1. Damn alarm keeps going off. Any ideas as to the cause?
    By SyA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th February 2006, 09:22
  2. Steering noise, any ideas?
    By HuntsA4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 19th December 2005, 19:21
  3. A part has fallen off my car. Any ideas where it is from?
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st September 2005, 18:46
  4. Weird noise on pulling off!!!
    By CJ A4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th January 2005, 12:12
  5. Help - Any ideas on a noise?
    By mramage in forum Classic Audi Forum
    Last Post: 10th October 2003, 21:45
