As above I pulled off and as I drove down the road a funny grindy noise came from the front wheel area, sounded as if a bit of wire was wrapped round the wheel or a bolt had come loose and was rubbing. I stopped the car had a look but nothing so I rolled it forward then back could still hear it then back once more and it went, not heard it since and Iv dove about 10 miles.
I scanned it just and it's thrown a fault code the only one there is this. [h=3]00526 - Brake Light Switch (F): Implausible Signal[/h][h=4]Possible Causes[/h]
As I'm going to inters it's bugging me anyone know if it's a easy fix or do I need to do anything to be on the safe side and would this be cause the above fault of the grinding noise.
Thanks, Chris.
- Wiring/Connectors from/to Brake Light Switch (F) faulty
- Brake Light Switch (F) faulty
- Check/Repair Wiring/Connectors from/to Brake Light Switch (F)
- Check/Replace Brake Light Switch (F)
- Check Measuring Value Blocks (MVB)
- FAQ 2.7. Many Automatic Transmission Control Modules will show a DTC 00526 or 17087 that indicates a faulty brake light switch. This can be ignored and will not appear if you press the brakes once before checking for Fault Codes.
Thanks, Chris.
