JMB RetrofitsChris Nott
Results 1 to 13 of 13
    Dec 2011
    Hockley Essex
    309
    Is a liquid gauge as good as a standard boost gauge?
    Hi all,
    Been looking into this for a while and haven't really found an answer yet ? And also been looking at standard gauges and in the photos i see standard and liquids in the same car making be believe that the liquid is not accurate?
    Any help would be great.
    Many thanks
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Have you read the review I did in the stickies?
    Liquid shows boost in 2 modes... first one reads from the MAP sensor (on engine codes that have them) and shows the same boost as the ECU will be seeing, the second is AGU mode where it calculates the boost base on a similar algorythem as the AGU ECU does to work out boost...
    MAP sensor mode is limited to the MAP sensor 1.5bar max... so will only report 22psi max and no vacuum
    AGU mode shows up to 30psi (iirc) and will show vacuum... not compared this on the dyno yet but will do if I think about it.. mine reads a bit differently to my boost gauge too
    That said... without calibrating the boost gauge there is no real way to compare... all you can be sure off is in MAP mode you will see what the ECU sees and what it uses to regulate boost
    <tuffty/>
    Dec 2011
    Hockley Essex
    309
    No i didn't , where do i find this and il have a read?
    Right ok i understand 95% of that as i am not totally clued up on all this yet but slowly learning. What is AGU mode ?
    Im really interested in getting the liquid as i like the idea of being able to scan for faults and the other features included in this bit of kit .
    Would you recommend buying one on you experience with one ?
    Many thanks
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    The stickies/FAQ link at the top of the 8L section...
    A3/S3 FAQ / How To's / Tuning Info STICKIES - PLEASE READ BEFORE POSTING
    I run a boost gauge and a Liquid gauge... personally I prefer the boost gauge for boost... its just better... I use the liquid in multi gauge most of the time but use it for EGTs or AFR mainly...
    As for fault codes... you should be aware that Liquid will only scan the ECU... it won't scan other modules around the car... VCDS is a better bet...
    If you have limited funds, buy a decent boost gauge and VCDS... if money isn't an issue then buy a decent boost gauge, VCDS and Liquid in that order
    <tuffty/>
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,391
    Yeh come on tuffty share! I wann know this too....... I like the look but £250 cash pound notes is not cheap!
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,391
    Ok you posted that before I had done eating my twirl, thanks lol! And I would get normal boost gauge anyway as prefer these! I do like look of liquid in vent though.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    The stickies are at the top of the section... nobody ever reads them
    <tuffty/>
    Dec 2011
    Hockley Essex
    309
    Cool! thanks for the info Tuffty . And as from now i will look at the stickies . Just one last question where is the best place to but VCDS from as i here the ebay jobbies are not much good ?
    Many thanks
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Look in the stickies of the VCDS forum here on ASN... ;P
    <tuffty/>
    Dec 2011
    Hockley Essex
    309
    Oh dear that wasn't a very good start on reading the stickies was it im off to read !
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Most if not all the sub forums/sections have stickies sat up the top...
    <tuffty/>
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,283
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    <tuffty/>
    I am often in the stickies...I always read them before upgrading certain parts.
    Also helped me post pics so I could create an avatar
    I think a gague will be one of my last mods
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,391
    A gague.......... What about a gauge ? Is that on your list? Lol
  1. Nuri's liquid S3 boost gauge
    By freegeek in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th January 2011, 18:02
  2. Liquid boost gauge
    By Danny Cawsey in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th February 2010, 12:47
  3. liquid leather any good?
    By doubledrat in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th October 2004, 21:02
  4. Digital boost gauge
    By Mo-S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th May 2003, 23:42
