Sky InsuranceAH Fabrications
Results 1 to 10 of 10
    James TQ's Avatar
    Apr 2012
    Essex
    548
    dodgy grinding feeling when braking?
    hey guys,
    basically what the issue is, when im going fast, A roads ect if im firmish on the brakes and theres a bump in the road or a dip them brake peddle feels like is grinding and you can feel it strongly in your foot, i have run vag com and no codes relating to this? i know my front disks are slightly warped would this have anything do with it?
    thnaks.
    MrTackalakalaka's Avatar
    Jan 2012
    Truro, Cornwall
    426
    Are they standard brakes? or drilled etc?
    I have the same thing with one of my rear brakes. They are pretty much brand new discs as well. Really bloody annoying. I may have to get it plugged in to see what codes come up/if any.
    My old discs were warped but didn't really have the grinding feeling.....they just broke unevenly and the steering wheel would wobble.
    It almost feels like the pads are somehow moving a tiny bit when mine feel like they are grinding.
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,391
    Again I can second the above, it is so annoying when I've just spent £400 on new discs and pads all round and fitting and this happens!
    Very irritating!
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,919
    ABS kicking in ? Just a thought.
    Gops's Avatar
    6th gear @7000rpm
    Coventry
    2,640
    ^ +1! It sounds like the ABS! Especially going over a bump or drain.
    Jun 2012
    Torqauy
    100
    I get this from front wen braking normally just fort it was normal as car just went thru mot fine.
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,391
    Why would it kick in just normal dry weather braking? Knackered sensor?
    Jan 2012
    Truro, Cornwall
    426
    Yeah.......Tuffty mentioned on a post i put a couple of days ago that it could be ABS sensor/wire. Would have thought something would have popped up code wise when you had it hooked up. Mine isn't toooo bad but its pretty annoying!! If you guys ever get yours sorted, would love to know how and costs etc
    James TQ's Avatar
    Apr 2012
    Essex
    548
    It's a pre face lift. No abs light. I was having a moment last night doing donuts on grass as a tapped the brake and it was there again ill have a mechanic check it :/ it seems like its a widespread problem so it will be interesting to resolve
    Jan 2012
    Truro, Cornwall
    426
    Yeah mine is prefacelift too. I keep thinking my rear callipers are knackered. If you could let me know what the mechanic finds that would be awesome. thanks
  1. Grinding Noise When braking, COULD IT BE MY WHEEL SPACERS?
    By AudiS3Quattro in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th January 2011, 22:43
  2. Shaky Steering wheel when braking
    By TDI in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th November 2004, 15:40
  3. Grinding Noise from Brakes
    By DamoS3Q in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th May 2004, 13:40
  4. Problem when braking
    By rickparmar in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th May 2004, 01:58
  5. Noise when braking at high speed ?
    By MingBluS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th February 2004, 15:09
