Volks AutosBadger5
    Squirrelofdoom's Avatar
    Feb 2012
    Surrey
    533
    Power steering pump oil leak
    Hi guys,
    Someone had a look at my car recently and mentioned that he thought there was an oil leak coming from the power steering pump...does this make any sense? He said oil was leaking from the sensor, possible around the o-ring between the sensor and the pump. I know nothing about the S3 power steering pump, but does he not mean power steering fluid rather than oil?
    I changed the cam cover gasket recently, but under a hard drive I still get a small amount of grey smoke coming up from the back of the engine and I can smell a burning smell in the cabin. Could this be a power steering fluid leak? I don't have any problems with the steering though. Does the location of the smoke make sense for that? Any help would be great as the burning smell is annoying / worrying.
    Cheers guys!
    Aran
    Feb 2012
    Surrey
    533
    bump?
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    738
    Power steering fluid is an oil so definately something you need to sort ASAP. I say this as someone who recently had to replace pump rack and steering oil cooler its an expensive thing to go tits-up it cost me £1900 at the stealers as the car was undriveable and I needed it fixing ASAP :^(
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    Feb 2012
    Surrey
    533
    Hi mate,
    Thanks for the info. Should there be any common places I should be looking for leaks? If I find one and replace said part, is it easy enough to top up / bleed the power steering system? Anyone got any pictures of locations of common leaks etc?
    Thanks guys!
    Aran
    Feb 2012
    Surrey
    533
    bumpers (sry)
    Sep 2009
    738
    Topping up is easy; just add the corrrect Audi PAS fluid to the reservoir and check with dipstick, and just turn steering lock to lock a few times to bleed, the system is not easy to check for leaks as its a plumbing maze, mine was in Audi 3 days before it all let go big time for a service and safety check lol and they didnt spot any leaks, (or so they claim)
  1. Power Steering Pump
    By ghost.s3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th June 2009, 11:17
  2. New power steering pump
    By AndyMac in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th September 2008, 13:40
  3. Power steering pump recon or replace?
    By Beef in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th March 2007, 09:07
  4. Alternater power steering pump belt probs
    By silveravant in forum Diesel forum
    Last Post: 22nd October 2006, 22:20
  5. Noisy Power Steering Pump
    By madkebab in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th September 2004, 12:21
