Monster MotorsportVolks Autos
Results 1 to 8 of 8
    scotty_24's Avatar
    Feb 2011
    Newcastle upon Tyne
    197
    Oil pick up pipe done!
    Done the pick up pipe and oil / filter change on the car today. Sump was caked in burnt oil so spent ages clearing it out.
    Revo map now booked for July 7th, can't wait!
    I highly recommend doing the pipe, the bits cost hardly anything an can save so much hassle later down the line!
    REVO Stage 2, Eibach anti roll bar kit, forge 007p diverter valve (yellow spring), Badger5 turbo intake pipe with Jetex filter and Neuspeed heat shield, Forge upper bost hoses, N75, DV and Cam breather hoses, XS Power 3" downpipe 200cell cat and 3" cat back system, Apex 30mm springs, N249 bypass, Oil catch can and PVC delete, Front Mount Intercooler............
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,748
    Nice one! This a job I need to do on mine. I doubt it's blocked as its been pretty well serviced but it can't do any harm! I have to change the sump anyway as the threads on the sump plug are a bit worse for wear ! Ordered a new one from ECS.
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
    scotty_24's Avatar
    Feb 2011
    Newcastle upon Tyne
    197
    Quote Originally Posted by Sam_ View Post
    I just wanted to do it for peice of mind before it gets REVO'd.
    My friend has a TT and the pipe blocked up on his, and took out his turbo. Not good!
    tonks s3's Avatar
    May 2012
    33
    Hi there would like to do this on my 2001 s3 amk just wondering how do I get to the pipe.. which pipe is it? :-) cheers
    scotty_24's Avatar
    Feb 2011
    Newcastle upon Tyne
    197
    Quote Originally Posted by tonks s3 View Post
    Theres a thread in the stickies about it, you have to remove the sump to grg to the pick up pipe,
    You'll need the pipe, o ring, sump sealant, oil and oil filter. I got all my parts from TPS as I work for VW.
    tonks s3's Avatar
    May 2012
    33
    Ahh coool thankyou mate! Great help
    danger S3's Avatar
    Jun 2010
    Edinburgh, Scotland
    354
    tonks s3's Avatar
    May 2012
    33
    Cheers mate spot on!
  1. Oil Pick up pipe Sludge
    By duffy78 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd February 2014, 15:18
  2. oil pick up pipe
    By jay1601 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th November 2011, 21:29
  3. Replace pick up pipe naturally, also clean oil feed / return pipe?
    By mikem1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th March 2011, 18:05
  4. Oil pick up pipe question.....
    By T0m in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 17th September 2010, 16:53
  5. Cost to replace oil pick up - sludge prevention!!
    By s3tle in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 18th July 2010, 13:22
