Monster MotorsportEM Tuning
Results 1 to 11 of 11
    Nov 2011
    138
    Under Revving when warm
    Hey guys,
    after a bit of help/advice.
    recently i have noticed that when i first start the car up in the morning (or at the end of work when it has been sat all day) the rev needle seems to "hunt" slightly up and down a bit, this is before the engine is warmed up and revving around the 1000/1100 rpm mark, i can also slightly hear the engine revving in time with this movement.
    also, when the car is up to heat and say i am sat in traffic, sometime the revs will drop to almost 500 (seems to sit at about 700 rpm normally) and the car almost stalls.
    i think there is also some hesitation accelerating and other little niggles which may all be related. I assume the common response will be "clean the throttle body" which i will be doing, i just dont have VAG com to reset it. I also wanted to know of any other possible causes.
    Thanks,
    James
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,115
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Strange as I was just searching for a problem very similar than you describe in your post! lol
    I'll be replacing the clutch pedal sensor to try and cure it initially.....£15 from TPS, and Audi are not that more if there closer to you.
    (I can't take any credit if it does cure it though.....thanks need to go to the people who post on here )
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    Sounds Vacuum related, check pipes under the manifold..
    Nov 2011
    138
    Cheers for the input guys.
    Will try and take a look for any damaged/split split vacuum hoses later on.
    James
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Yeh sounds similar to the issue i had a while back which turned out to be a split vac hose under the manifold. Really have a close look at all the hoses because I couldn't actually see the split until i moved the hose.
    1999 APY S3 Imola Yellow
    PS3: Broady_11
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,061
    A good tell tale is greasy residues on the pipes...
    Nov 2011
    138
    Ok then, is it most likely to be the ones under the inlet mani? are there other common culprits?
    also what size internal diameter is the standard vacuum hose (i guess the ones under the inlet)
    Nov 2011
    138
    i had a look today and cant seem to see/feel any split or damaged hoses under the inlet or around the N249 or anywhere.
    I did however notice that the pipe on the bottom of the hockey puck valve looking like this...
    IMAG0214 by Mcpickering2009, on Flickr
    IMAG0215 by Mcpickering2009, on Flickr
    Any thoughts?
    just to re-iterate the problem with the revs hunting is only when cold and the under revving only when warm.... ?
    thanks,
    James
    scotty_24's Avatar
    Feb 2011
    Newcastle upon Tyne
    188
    Quote Originally Posted by mcpickering View Post
    Any thoughts?
    thanks,
    James
    My pipe collapsed like this, I just bought the forge one to replace it
    REVO Stage 2, Eibach anti roll bar kit, forge 007p diverter valve (yellow spring), Badger5 turbo intake pipe with Jetex filter and Neuspeed heat shield, Forge upper bost hoses, N75, DV and Cam breather hoses, XS Power 3" downpipe 200cell cat and 3" cat back system, Apex 30mm springs, N249 bypass, Oil catch can and PVC delete, Front Mount Intercooler............
    Nov 2011
    138
    any idea which one i would need for an AMK, also i want to replace some of the other whilst im there. any suggestions on which?
    Nov 2011
    138
    bump
  1. ECU Engine temp sensor - difficult start when warm
    By James09 in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th September 2009, 19:52
  2. a6 1.8t missing when warm
    By stu412t in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 14th April 2009, 19:10
  3. Starting when warm - help
    By Morzy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 21st February 2009, 16:48
  4. Audi Coupe 16v - Cuts out when warm
    By MrRP in forum Classic Audi Forum
    Last Post: 18th December 2008, 13:18
  5. Over Revving when changing gear - Fixed!
    By h3msy in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th April 2005, 13:21
