MrTackalakalaka
Hello everyone
About a month ago i changed the brakes on my car. Complete set of new standard discs with Mintex pads. I also gave the callipers a quick clean/service while i was there
All went smoothly, no hard braking for at least 100 miles when i first fitted them and all seemed fine.
This weekend i noticed that when i pressed my foot on the pedal fairly lightly when I'm going slow........it feels like there is a click in the brake pedal and a scraping noise coming from the rear brakes. Almost as if the ABS kicks in a bit. Isn't ABS only in the front discs?
Also if I'm coming up to a junction and start applying the brakes lightly........there is a scraping noise but it only sounds like half the disc is rubbing.
My discs can't be warped already could they? I changed my old discs (dotted and grooved) because they were warped.
When i jacked the car up.......i span both rear wheels.......the near side rubs as much as you would normally expect but the off side rubs quite a bit. When i changed the brakes i made sure the pistons were wound right back as far as they would go. The front discs seem fine.
When i brake the car doesn't seem to pull or anything, no wobbles etc.
Not really sure what it could be.
Anyone got any ideas?
Scott
Scott
