EM TuningVolks Autos
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    550cc injectors and the KRKTE Value...
    I think my KRTKTE value may be wrong for my injectors, causing the lean top end running, (diagnosed as a fuel pump issue)
    mine are set at 0.0597 where as others are all around 0.0725 which allows more fuelling per m/s. can anyone confirm this? aka Bill/tuffty....
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,572
    KRKTE on std 370's is around 0.08 odd (would need to look it up...) 550's normally come in at 0.05 odd from memory... my 630's are 0.04 odd...
    Non wideband are tuned differently to wideband cars on WOT... not done a lot with them personally but FKKVS springs to mind which is a correction map... I believe this to be the one that is dialled in to sort fuelling on APY's as the lambda is only used for idle, part throttle and cruise...
    <tuffty/>
    Andrew@A.L.D's Avatar
    Cylinder Head Master
    Jun 2009
    Leeds
    3,469
    Wideband conversion next dave??
    RIP S3dave/David Marshall stickers now available
    FOR SALE
    Sparco Torino 2 sport seats, None resonated Milltek exhaust,
    Adjustable FPR from 1-5 bar, 2 sets of Unused ARP 3/8 2000 rod bolts, relentless 200 cell cat pipe, Std AGU Crankshaft. Ported & Reconditioned Cylinder head service.
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,121
    Yeah maybe Andrew,, putting the pump on this weekend and got a transitional phenolic gasket to go on, then back to the tuners, if it is still a poor out put i will be going back to the drawing board,, wideband + some other turbo.....
    superkarl's Avatar
    MAN OF STEEL
    Mar 2010
    Liverpool/Southport. N west
    7,533
    you SHOULD have a 330hp capable car at least with your spec, i hope it goes well for you and the car puts out mate.
    its crazy as to why it did so poorly.
  1. Help needed which rs4 injectors and FRV for the 2.0 tfsi part numbers/advice
    By AARON77 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th November 2011, 18:36
  2. And the winner is:
    By Ess_Three in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th December 2004, 10:35
  3. The Old and the New
    By SiCotty in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th September 2003, 16:07
  4. Bad and the good
    By will_S3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th July 2003, 18:50
  5. Sony Head units and the instrument cluster display
    By Ram in forum In-Car Entertainment
    Last Post: 14th April 2003, 23:30
