AH FabricationsChris Nott
    Sep 2011
    Rotherham
    55
    Stuck on bleeding brakes
    Just bled them with eezibleed, Pedal is firm with car off. Turn car on and pedal goes to the floor. Any ideas? Thanks in advance.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,607
    Bled the master cylinder? pedal will be hard with the engine off as the vacuum will disipate as you pump the pedal with the engine off... this is by design
    <tuffty/>
    s33nyboy12's Avatar
    May 2012
    East midlands
    1,391
    <tuffty/>
    Also tuffty as you pointed out to me , 2 nipples on b.m.c are very stiff and snap easily, use ptfe lube or wd40 , lots of it!
  1. Bleeding brakes/ECS kit
    By Pontio in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th September 2005, 11:55
  2. Bleeding Brakes and ABS
    By a3tdi in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd February 2005, 19:12
  3. Bleeding Brakes
    By cclarke184 in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th June 2004, 20:20
  4. Bleeding brakes A3
    By marcsnoz in forum Handling
    Last Post: 16th July 2003, 09:47
  5. Bleeding Brakes A3
    By marcsnoz in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th July 2003, 09:41
