AH FabricationsVolks Autos
Page 3 of 3 FirstFirst 123
Results 81 to 106 of 106
Like Tree17Likes
Thread: Lorryz S3 8l
  1. #81
    lorryz's Avatar
    Apr 2012
    Sydney, Australia
    102
    I got a few things done this weekend. Starting with the gearbox dog bone bushes.
    I had previously fitted the yellow bushes to the dog bone, but i forgot to replace the centre circular bush.
    I used a vice, 20mm socket and a couple bits of wood to push the old bush out.
    The rubber in the bushing fell apart in my hands, so it was well over due for changing.
    I used the same method as above to push the new poly bush into its home.
    Once fitted, the car felt better under heavy load shifting.
    Next, I fitted Neuspeed RS adjustable control arms.
    I wanted to fit polybushed arms after hearing other members having issues with ball joint bushes. But i got these for a good price and so far haven't had any issues.
    I fitted them as the top arms, since they were to big for the light auto level bracket.
    I found it surprisingly easy. 3 bolts per side and I was done.
    Next on the list, Aero-wipers. A set of late mk4 arms and wipers popped up cheap. So i snapped them up.
    And i got the polo aero arm and wiper to match.
    Last job were the brakes. I was due to fit new pads and rotors on the rears.
    While i was there, i gave them all a new coat of paint.
    s3dave likes this.
  3. #82
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,648
    Looking good mate. Those Neuspeed arms look really awesome quality. A guy in europe has been running them with the original rose joints for 75,000 miles so they're probably decent quality
    Handling mods++. GTX30 soon-ish. Hiding parts from the mrs since 2011. Build thread
  4. #83
    Apr 2013
    Hey, amazing looking car there mate. What colour is it?
  5. #84
    lorryz's Avatar
    Apr 2012
    Sydney, Australia
    102
    Quote Originally Posted by Sam_ View Post
    Ah, awesome. That makes me feel better
    They looked like good quality items, but i haven't seen many people with them ( I guess there a bit over priced).
    Quote Originally Posted by Safinn View Post
    Thanks mate, I believe its Dolphin Grey.
  6. #85
    lorryz's Avatar
    Apr 2012
    Sydney, Australia
    102
    Another small update. Got big things lined up for the next few weeks.
    But this weekend I installed a Creationsmotorsport stainless steel footrest. Its rubber backed and comes with everything needed to fit.
    Plus it looks pretty sweet.
    Next I installed some footwell lighting, to show off the petals and provide some courtesy lighting.
    Cheap and easy mod, I used some red LED strips with sticky backing.
    And I wired it into the Light switch. So it comes on with the the rest of the red interior lights.
    The pictures don't do it much justice, but this mod does look very good at night.
    And it it looks like standard lighting.
  7. #86
    lorryz's Avatar
    Apr 2012
    Sydney, Australia
    102
    FMIC
    AH Fab v2 Front mount intercooler turned up yesterday. Its a quality looking cooler.
    Should make a bit if a difference when summer comes around.
    Unfortunately, It did sustain some damage while in transit.
    It looks like the passenger side pipework took a pretty big knock.
    I pushed the dent out as best as I could. Hopefully it will hold boost. Now waiting on the silicone pipes to check my bodge.
  8. #87
    Oct 2012
    South Africa
    268
    Looking good, Pity about the damage to the inlet pipe.
  9. #88
    lorryz's Avatar
    Apr 2012
    Sydney, Australia
    102
    Quote Originally Posted by Sidey View Post
    Yeah, I can't blame AH fabs, They did a pretty good job packing it up.
    Its down to UPS and travelling half way around the world. Oh well.
  10. #89
    Apr 2013
    JHB, South Africa
    162
    Very clean ride you have man!!! Looking good
  11. #90
    lorryz's Avatar
    Apr 2012
    Sydney, Australia
    102
    FMIC
    Ok, So I got the AH Fab v2 cooler fitted. As per the fmic thread.
    I needed 2 x 63mm 90 deg alloy bends and 2 x 63mm silicon 90 deg elbows to make this work.
    However, i found that the pipework on the passenger side, didn't quiet line up with the stock oem straight hose.
    So for the test drive, I improvised and used the kinked rubber hose that connects the stock driver side cooler to the center connector pipe. And it worked a treat.
    Test drive ready.
    I probably could have left the oem hose on there. With no problems.
    But I decided to replace it with a fresh 63mm silicon 45 deg elbow. While i still had the bumper off.
    Trimmed down bracket for hood latch and horns moved to the usual spot on the passenger side.
    Everything back together and the car is looking meaner than ever. Can't wait for summer.
  12. #91
    s3dave's Avatar
    TFSI Hybrid
    west yorks
    10,067
    Very Tidy install....
    lorryz likes this.
  13. #92
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,648
    I used that same OEM hose (I think I said in the thread at some point) and still do to this day. How did you find the bumper trimming? I still need to take mine off and trim some more when I replace the horns. Might be a job for this weekend if the weather's decent.
  14. #93
    lorryz's Avatar
    Apr 2012
    Sydney, Australia
    102
    Yeah i did trim a bit behind the grill. And yes it was very tight... still is tbh.
    The main issue i had was the bolts holding the lcr splitter fouled on the cooler, so they had to be ground down a bit. And i put some 3mm thick rubber down to stop them rattling.
    Yeah I have a set of hella supertones to go on. I just need to find them.
  15. #94
    lorryz's Avatar
    Apr 2012
    Sydney, Australia
    102
    I've always found the horn on these cars a bit weak, so I went for a dig through my storage and found a set of Supertones from my old subaru.
    I could have hidden them down where I put the stock horns, but I wanted to see how they'd look on an audi
    I attached them using a bit of flat bar, as that's what I had hanging around. And it works fine.
    But if I was going to spend the money, a 90 degree angle probably would have been the better choice.
    Air temp sensor re-relocated back to its stock-ish location.
    I might black out the audi rings. A job for another day.
  16. #95
    BenJee_S3's Avatar
    Mar 2013
    Peterborough/Spalding
    137
    Follow BenJee_S3 On Twitter Add BenJee_S3 on Facebook Visit BenJee_S3's Youtube Channel Visit BenJee_S3's Instagram Channel
    Looks great mate, love that colour!
    lorryz likes this.
  17. #96
    Gordie_S3's Avatar
    Feb 2013
    Melbourne, Australia
    72
    You're all set for summer!
    I need to sort mine before summer.
    Looking good
    Stage 2 S3 8L + other mods
  18. #97
    lorryz's Avatar
    Apr 2012
    Sydney, Australia
    102
    I bought this heat shield ages ago from liquids3 and have finally gotten around to fitting it.
    It looks very oem after a coat of silver manifold paint.
    Next a gave plasti dipping a go.
    I must say I love this product, as its 100% reversible and a 1000 time easier to use over something like vinyl wrap.
    For the rear, you simply mask off the badges, spray it on and peel off the excess. Amazing.
  19. #98
    samurai's Avatar
    Nov 2013
    Slovenia
    51
    what heat shield is that? Where did you get it?
    Looks good that black painting you did but now the mirrors are only chrome thing on your car and seems to me that not fit well anymore on car but thats just my opinion, its your car and if you like it then is ok.
  20. #99
    sssline's Avatar
    Apr 2012
    Essex/London
    134
    Quote Originally Posted by lorryz View Post
    How long do you think the plastidip will last, or is it a temporary measure to see if you like it's all blacked out?
  21. #100
    lorryz's Avatar
    Apr 2012
    Sydney, Australia
    102
    Quote Originally Posted by samurai View Post
    I bought I from a member off here named liquids3. It was probably well over a year ago now. I have no idea if he still makes them.
    I see what your saying about the chrome mirrors. In the flesh, there is enough alloy on the car with the wheels and the fmic to tie in the mirrors.
    Personally I think the alloy/chrome mirrors on all S and RS model audi's help make the car, what it is.
  22. #101
    lorryz's Avatar
    Apr 2012
    Sydney, Australia
    102
    Quote Originally Posted by sssline View Post
    I believe it meant to last a while. If it gets chipped, you just peel it off and spray more on. Doesn't get any easier than that.
    I removed the front grill to spay it as I had the bumper off already. But you can do it with the badges still on the car. It just requires more prep work like with the rear.
  23. #102
    CazzaVR's Avatar
    Sep 2013
    Gloucestershire
    132
    Awesome work mate! The front end looks immense. Was in two minds about the Cupra splitter, but after seeing yours, think I'll definitely get one now
  24. #103
    lorryz's Avatar
    Apr 2012
    Sydney, Australia
    102
    Camber plates and Headlights
    Hi all, I had a few more things turn up.
    Firstly, Silver project camber plates. I wasn't in the market for a set, but they popped up at a really good price.
    I will be fitting as soon as my new sway bar links arrive.
    Second, A set of Ebay headlights.
    After a few disappointing headlight restoration sessions. I decided to buy a set of cheap donor headlight units strip for parts. Mainly the exterior glass/plastic.
    While I had a set of throw away headlight on the bench, I decided to experiment with a DRL (day time running light) Idea ive had for a while. Which utilises the projector lenses.
    I'm Actually quite happy with how it turned out. And I will do a full howto this weekend when I incorporate it into my OEM headlights.
  25. #104
    Sam_'s Avatar
    Down under
    Mar 2011
    Sydney, Australia
    2,648
    Very cool. I've wanted to sort out the sidelights on mine for a while but put it off. I was going to just fit LED sidelights though. I know what you mean about polishing the fronts. Still not happy with mine....
  26. #105
    lorryz's Avatar
    Apr 2012
    Sydney, Australia
    102
    Headlight glass and DRL's
    As I mentioned in my earlier post.
    I bought a pair of cheap ebay headlights so I could pinch the exterior glass and reuse it on my OEM headlight unit.
    I then tried a DRL idea I had, on the cheap lights (as I had no further use for them). And it turn out pretty well.
    So I incorporated them into my current headlight units and here's a quick how to, for anyone that is interested:
    Needed
    - 2 x T10 LED's - White ( I chose a simple 4 bulb smd style, as it should resist the extreme heat of the xenon bulbs.)
    - 2 x T10 lamp holders - I picked push in types.
    - 2 x Rubber Grommets 5/16"i.d X 9/16"o.d (optional)
    - Drill & drill bits
    - Heat gun or oven to separate headlights.
    - Wiring
    This is how cloudy and pitted my headlight looked prior to the swap.
    You remove the internal headlight assembly winding the alignment cogs clockwise until it pops out.
    The projector is only held to the shroud by 3 bolts
    Then the lens can be removed, leaving the plastic cone and light shield.
    I'm using the push type T10 sidelight holder borrowed from my second headlight set.
    Since its small and easy to install.
    Next, I drilled an appropriate sized hole for the bulb holder.
    The projector cone is made of plastic, so you must start small and work up to the larger dill bits.
    I located the hole at the bottom, slightly off centre. Due to the shape of the projector.
    Try to locate the hole as close to the projector shield as possible.
    I fitted a 5/16"i.d X 9/16"o.d Rubber Grommet to help secure the T10 bulb holder.
    This is how it should look,
    In this location the LED is out of the way of the xenon bulb and wont disrupt the main beams light output.
    I drilled and located new wires for the LED here.
    Bolt everything back together and test before resealing.
    And Yes I did paint my headlights red.
    Wire into an ignition 12v live. I use the one under the drivers dash.
    No Daytime pics yet, I need to give the car a good clean first.
    Final note: They won't be as bright as real DRL's, but the look a whole lot meaner.
    You could probably make them brighter by using larger LED, but then you run a larger the risk of them failing.
  27. #106
    vrbob's Avatar
    Jun 2007
    Southampton
    2,291
    Good work nice to see more people making their own mods and that defo looks better than the aftermarket LED strips everyone uses
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
