EM TuningAH Fabrications
Results 1 to 9 of 9
    Jun 2012
    6
    Unhappy Audi A3 2001 speedo problems
    Hi guys,
    I recently purchased an Audi A3 tdi facelift model on an X reg. The dials were not working, i.e. speedometer, rev counter,fuel gauge and .temperature gauge. The reverse light was also not working and the ESP light was on. The digital display works fine.
    I done a bit of research online to see anything for the symptoms I was having. So I checked the wire leading to the speed sensor and it was cut so I repaired that and then cleaned the speed sensor and its connector. The speed s ensor seemed fine so I put everything back together again thinking everything would be fixed.
    Started the car up but speedo was still the same but the reverse light was now working! Strange!
    So now I still have a faulty speedo and still have an ESP light showing.
    Can any of you guys help?
    PS I've tried to read codes with a cheap OBD II reader off fleabay but have no codes.currently do not have access to a VAG COM
    Jun 2012
    6
    The speedo is faulty. Can anyone recommend a cluster repair specialist?
    Danio's Avatar
    AUDI-MANIACS.COM
    Aug 2011
    Skelmersdale WN8
    187
    Can U make a photo of your present clocks??
    Currently not in the country
    Jun 2012
    6
    I'll get it up in the morning. Car's in the garage at the moment.
    Feb 2012
    Pie eating land
    1,354
    Follow ruffrida On Twitter Visit ruffrida's Youtube Channel
    Quote Originally Posted by maaqib View Post
    Clusters Uk are the best really, but i wouldn't even bother with that, get a set of clocks, bout £60 then have them re programmed to your car, if you live in the northwest Danio would be your best bet, he is a whizz when it comes to audi electrics. But that defo sounds like they are fooked, just done the upgrade on my 2000 plate TDI(thank you danio)
    B6 1.9tdi Quattro Avant Sport:
    My Build Thread = http://www.audi-sport.net/vb/a4-a4-c...so-begins.html
    Coming soon: -35mm Springs, Colour coded FOG grills, Trip stalk upgrade.
    Wish List; FMIC, BV43 turbo, Bigger Remap, Fat Clutch,Full Stainless, S4 Brakes, 5m mspacers - front, 10mm spacers rear, MFSW.
    Jun 2012
    6
    Quote Originally Posted by ruffrida View Post
    The cheapest I can find is £100 for repairing my clocks. Will it work out cheaper to get another cluster reprogrammed and mileage reset? I'm in Bedfordshire so no way I can get up to where Danio is!
    Car is still in the garage so won't be able to upload pics til tomorrow now.
    Jun 2012
    6
    Oh and ESP light is due to 01423 - Lateral Acceleration Sensor (G200) being faulty. Found some cheap sensors in Fleabay so need to check if part numbers are the same.
    Danio's Avatar
    AUDI-MANIACS.COM
    Aug 2011
    Skelmersdale WN8
    187
    ...just done the upgrade on my 2000 plate TDI(thank you danio)
    Any Time Adam. BTW I'vd got that washer bottle for you now.
    If you get new mean second hand clocks till 23-24 of June then I would be able to come to you.
    Jun 2012
    6
    Quote Originally Posted by Danio View Post
    Cheers, I drop you an PM
  1. Audi S3 cylinder head problems!! 2001 AMK
    By stoneys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd February 2012, 18:06
  2. Audi s3 2001 electrical problems :(
    By Fige18 in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th November 2011, 21:51
  3. 1996 Audi 80 Cabriolet - Roof Problems
    By stellarborne in forum Classic Audi Forum
    Last Post: 8th July 2006, 20:30
  4. speedo problems
    By imported_tacka in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 13th September 2004, 20:10
  5. Audi a4 2001 glove box mounted cd changer
    By belton in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th July 2004, 17:10
