any help much appreciated.
many thanks to Sailo (Jakob) from the forum for doing a diagnostics log for me.
i've noticed a major power loss low down especially torque from take off.
since the power loss i've cleaned the vanes in the turbo, removed the egr (egr delete), de cat and a front mount intercooler.
none of the mods made any difference to the power.
there was two vaccum pipes which were going to the egr valve which i have now blanked off.
The car does seem to react better when cold but still not 100% of what it used to be.
there must be some explanation to why i have lost so much power.
I have installed a boost gauge to check what boost im running at, the maximum boost is above 20psi around 25-30 i would say, its hard to say as it go's off the scale.
i have a data log from the MAF and Boost sensor. 2 logs of each i believe.
the logs were done on flat ground motorway from 3k to redline.
Anyone know how to read data logs and know what the data means?
Any help is much appreciated.
Friday | 1 | June | 2012 | 15:04:00:44690 | VCDS Version: Release 11.11.3 (x64) | Data version: 20120401 | ||
038 906 019 FT | 1.9l R4 EDC 0000SG 1527 | |||||||
Group A: | '010 | Group B: | Not Running | |||||
MAF | Atmos. pressure | Intake air press. | Throttle | |||||
TIME | 900-1250 | sensor -f96- | 2100-2600 | 100% | TIME | |||
Marker | STAMP | mg/str | mbar | % | STAMP | |||
0.3 | 725.2 | 1009.8 | 1509.3 | 54.1 | ||||
0.65 | 1053.5 | 1009.8 | 1860.3 | 72.2 | ||||
0.97 | 1078 | 1009.8 | 2234.7 | 79.6 | ||||
1.3 | 1004.5 | 1009.8 | 2199.6 | 92.9 | ||||
1.63 | 1019.2 | 1009.8 | 2176.2 | 100 | ||||
1.97 | 1033.9 | 1009.8 | 2211.3 | 100 | ||||
2.29 | 1029 | 1009.8 | 2234.7 | 100 | ||||
2.63 | 1009.4 | 1009.8 | 2246.4 | 100 | ||||
2.97 | 994.7 | 1009.8 | 2246.4 | 100 | ||||
3.3 | 980 | 1009.8 | 2258.1 | 100 | ||||
3.63 | 960.4 | 1009.8 | 2246.4 | 100 | ||||
3.99 | 950.6 | 1009.8 | 2223 | 100 | ||||
4.31 | 916.3 | 1009.8 | 2199.6 | 100 | ||||
4.65 | 906.5 | 1009.8 | 2176.2 | 100 | ||||
4.98 | 882 | 1009.8 | 2141.1 | 100 | ||||
5.33 | 877.1 | 1009.8 | 2129.4 | 100 | ||||
1 | 5.68 | 578.2 | 1009.8 | 1907.1 | 0 | |||
6.01 | 504.7 | 1009.8 | 1462.5 | 0 | ||||
6.37 | 485.1 | 1009.8 | 1275.3 | 0 | ||||
6.7 | 460.6 | 1009.8 | 1181.7 | 0 | ||||
7.04 | 465.5 | 1009.8 | 1146.6 | 0 | ||||
7.36 | 465.5 | 1009.8 | 1123.2 | 0 | ||||
7.71 | 465.5 | 1009.8 | 1123.2 | 0 | ||||
8.04 | 450.8 | 1009.8 | 1111.5 | 0 | ||||
8.38 | 460.6 | 1009.8 | 1111.5 | 0 | ||||
8.74 | 465.5 | 1009.8 | 1111.5 | 0 | ||||
22.12 | 465.5 | 1009.8 | 1088.1 | 0 | ||||
22.46 | 460.6 | 1009.8 | 1088.1 | 0 | ||||
22.79 | 470.4 | 1009.8 | 1088.1 | 0 | ||||
23.14 | 465.5 | 1009.8 | 1088.1 | 0 | ||||
23.45 | 465.5 | 1009.8 | 1088.1 | 0 | ||||
23.8 | 465.5 | 1009.8 | 1088.1 | 12.2 | ||||
24.14 | 480.2 | 1009.8 | 1088.1 | 11.4 | ||||
24.46 | 480.2 | 1009.8 | 1088.1 | 15.3 | ||||
24.81 | 490 | 1009.8 | 1088.1 | 36.5 | ||||
25.14 | 666.4 | 1009.8 | 1263.6 | 42 | ||||
25.48 | 656.6 | 1009.8 | 1415.7 | 41.2 | ||||
25.83 | 637 | 1009.8 | 1450.8 | 40 | ||||
26.14 | 627.2 | 1009.8 | 1427.4 | 39.2 | ||||
26.48 | 622.3 | 1009.8 | 1404 | 37.6 | ||||
26.83 | 583.1 | 1009.8 | 1333.8 | 38 | ||||
27.13 | 627.2 | 1009.8 | 1333.8 | 44.7 | ||||
27.48 | 715.4 | 1009.8 | 1439.1 | 46.7 | ||||
27.82 | 720.3 | 1009.8 | 1556.1 | 40.4 | ||||
28.14 | 641.9 | 1009.8 | 1497.6 | 42 | ||||
28.5 | 646.8 | 1009.8 | 1462.5 | 42.4 | ||||
28.84 | 641.9 | 1009.8 | 1450.8 | 41.6 | ||||
29.16 | 627.2 | 1009.8 | 1450.8 | 32.2 | ||||
29.51 | 558.6 | 1009.8 | 1322.1 | 34.5 | ||||
29.83 | 568.4 | 1009.8 | 1298.7 | 29.8 | ||||
30.17 | 558.6 | 1009.8 | 1287 | 27.8 | ||||
30.52 | 524.3 | 1009.8 | 1240.2 | 21.2 | ||||
30.85 | 524.3 | 1009.8 | 1193.4 | 20.8 | ||||
31.19 | 519.4 | 1009.8 | 1181.7 | 23.1 | ||||
31.53 | 509.6 | 1009.8 | 1170 | 24.7 | ||||
31.84 | 504.7 | 1009.8 | 1158.3 | 23.1 | ||||
32.19 | 509.6 | 1009.8 | 1158.3 | 22.4 | ||||
32.53 | 509.6 | 1009.8 | 1146.6 | 17.6 | ||||
32.85 | 509.6 | 1009.8 | 1146.6 | 0 | ||||
33.2 | 499.8 | 1009.8 | 1134.9 | 0 | ||||
33.53 | 460.6 | 1009.8 | 1111.5 | 15.7 | ||||
33.85 | 485.1 | 1009.8 | 1088.1 | 18 | ||||
34.2 | 485.1 | 1009.8 | 1088.1 | 22.4 | ||||
34.52 | 485.1 | 1009.8 | 1099.8 | 22.4 | ||||
34.86 | 509.6 | 1009.8 | 1111.5 | 23.5 | ||||
35.21 | 509.6 | 1009.8 | 1123.2 | 23.5 | ||||
35.52 | 509.6 | 1009.8 | 1123.2 | 23.5 | ||||
35.86 | 494.9 | 1009.8 | 1123.2 | 23.5 | ||||
36.17 | 509.6 | 1009.8 | 1123.2 | 23.5 | ||||
Friday | 1 | June | 2012 | 15:05:48:44690 | VCDS Version: Release 11.11.3 (x64) | Data version: 20120401 | ||
0.03 | 627.2 | 1009.8 | 1427.4 | 40 | ||||
0.35 | 622.3 | 1009.8 | 1404 | 40 | ||||
0.67 | 617.4 | 1009.8 | 1380.6 | 41.2 | ||||
1.02 | 774.2 | 1009.8 | 1462.5 | 56.9 | ||||
1.35 | 1058.4 | 1009.8 | 1883.7 | 76.9 | ||||
1.71 | 1087.8 | 1009.8 | 2234.7 | 99.2 | ||||
2.05 | 1009.4 | 1009.8 | 2234.7 | 100 | ||||
2.39 | 1038.8 | 1009.8 | 2199.6 | 100 | ||||
2.72 | 1063.3 | 1009.8 | 2223 | 100 | ||||
3.06 | 1048.6 | 1009.8 | 2234.7 | 100 | ||||
3.39 | 1033.9 | 1009.8 | 2258.1 | 100 | ||||
3.72 | 1024.1 | 1009.8 | 2269.8 | 100 | ||||
4.05 | 1014.3 | 1009.8 | 2281.5 | 100 | ||||
4.4 | 989.8 | 1009.8 | 2269.8 | 100 | ||||
4.72 | 975.1 | 1009.8 | 2269.8 | 100 | ||||
5.07 | 955.5 | 1009.8 | 2246.4 | 100 | ||||
5.4 | 935.9 | 1009.8 | 2223 | 100 | ||||
5.71 | 921.2 | 1009.8 | 2187.9 | 100 | ||||
6.06 | 916.3 | 1009.8 | 2164.5 | 100 | ||||
6.38 | 891.8 | 1009.8 | 2141.1 | 100 | ||||
6.73 | 754.6 | 1009.8 | 2094.3 | 0 | ||||
1 | 7.07 | 514.5 | 1009.8 | 1626.3 | 0 | |||
7.4 | 499.8 | 1009.8 | 1345.5 | 33.3 | ||||
7.75 | 661.5 | 1009.8 | 1322.1 | 52.5 | ||||
8.09 | 597.8 | 1009.8 | 1509.3 | 26.7 | ||||
