Volks AutosAH Fabrications
    Jan 2012
    12
    Wires shorted while changing broken coil pack connector.. car won't fire
    As title 2 wires shorted while changing a broken connector , ignition was off but they wielded together. Checked all fuses nothing blown. now car just turns over but doesn't fire. Anyone have any idea's?
    Thanks in advance
    Customboy's Avatar
    Jan 2012
    SE London
    836
    Have u ran a vagcom check mate and doubled checked everything maybe even d/c battery and leave it for a while and see if that works
    p
    THE BLUE BEAST, TAKEN FROM ME, GONE BUT NOT FORGOTTEN
    RTECH STAGE 2 REMAP NOW RUNNING 223 BHP AND 253 FTLB OF TORQUE,
    SUBARU IMPREZA WRX ESTATE SOON TO BE RUNNING 340 BHP
    ANTI LAG/LAUNCH CONTROL/MAF LESS/ LOVE IT !!
    Jan 2012
    12
    vcds say's engine control module no communication !
    Jan 2012
    12
    tried disconnecting battery for 20 mins
    VCDS Version: Release 11.11.3 (x64)
    Data version: 20120401
    Monday,04,June,2012,16:53:46:56959
    Chassis Type: 8L - Audi A3/S3
    Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
    Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl
    Part No: 8N0 907 379 E
    Component: ESP 20 CAN V005
    Coding: 18448
    Shop #: WSC 06435
    VCID: 3E750BBA3A6C949
    1 Fault Found:
    01314 - Engine Control Module
    49-00 - No Communications
    Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
    Part No: 8L0 820 043 M
    Component: A3 KLIMAVOLLAUTOMAT_D77
    Coding: 03141
    Shop #: WSC 06435
    VCID: 326D2F8AFE34409
    No fault code found.
    Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
    Part No: 8L0 959 655 J
    Component: Airbag Front+Seite 3008
    Coding: 01104
    Shop #: WSC 06435
    VCID: 458764565FBAC71
    Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
    Part No: 8L0 920 980 B
    Component: AB-KOMBIINSTR. VDO D11
    Coding: 01444
    Shop #: WSC 00000
    Component: AUZ7Z0Y1524795
    ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ AUZ7Z0Y1524795
    1 Fault Found:
    01177 - Engine Control Unit
    Address 22: AWD Labels: 02D-900-554.lbl
    Part No: 02D 900 554 B
    Component: HALDEX LSC ECC 0006
    VCID: 1F4BD63E9DA6FD1
    1 Fault Found:
    Address 35: Centr. Locks Labels: 8D0-862-257.lbl
    Part No: 8L0 862 257 P
    Component: CV-Pump, Alarm, RC D13
    Coding: 15178
    Shop #: WSC 06435
    VCID: 428D7F4A4E94F09
    2 Faults Found:
    01134 - Alarm Horn (H12)
    76-10 - Terminal 30 missing - Intermittent
    77-10 - Internal Supply Voltage - Intermittent
    Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
    Part No: 4B0 951 173
    Component: Innenraumueberw. D03
    Coding: 00001
    Shop #: WSC 00000
    VCID: E0C915C26058029
    Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
    Part No: 4B0 907 357
    Component: LEUCHTWEITEREGLER D004
    Coding: 00002
    Shop #: WSC 06435
    VCID: E5C704D67F7A671
    Aug 2010
    1,540
    there must be a protection fuse somewhere. you got a wiring diagram?
    Jan 2012
    12
    checked all fuses in car and under bonnet
    Problem is now resolved
  1. coil pack wiring harness?
    By Splodge in forum A3/S3 Forum (8L Chassis)
    Last Post: 3rd November 2011, 22:09
  2. Changing Coil packs. Is there a guide
    By Westy in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th July 2009, 15:55
  3. Slight hesitation, already had a coil pack changed, any ideas?!
    By Cossie_boy in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st December 2008, 17:11
  4. 4 Spark Plugs & 4 Coil Packs Later...Car Still Stuttering
    By Tekin in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th June 2008, 22:18
  5. Help - Coil Pack changed but still not running right!?!?...
    By Jodi in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th January 2006, 19:58
