Wires shorted while changing broken coil pack connector.. car won't fire
iamramaz
NULL
As title 2 wires shorted while changing a broken connector , ignition was off but they wielded together. Checked all fuses nothing blown. now car just turns over but doesn't fire. Anyone have any idea's?
Thanks in advance
Have u ran a vagcom check mate and doubled checked everything maybe even d/c battery and leave it for a while and see if that works
vcds say's engine control module no communication !
tried disconnecting battery for 20 mins
VCDS Version: Release 11.11.3 (x64)
Data version: 20120401
Monday,04,June,2012,16:53:46:56959
Chassis Type: 8L - Audi A3/S3
Scan: 01 02 03 08 15 16 17 22 35 37 45 55 56 57 75 76
Address 03: ABS Brakes Labels: 8N0-907-379-MK20-E.lbl
Part No: 8N0 907 379 E
Component: ESP 20 CAN V005
Coding: 18448
Shop #: WSC 06435
VCID: 3E750BBA3A6C949
1 Fault Found:
01314 - Engine Control Module
49-00 - No Communications
Address 08: Auto HVAC Labels: 8L0-820-043-2D.lbl
Part No: 8L0 820 043 M
Component: A3 KLIMAVOLLAUTOMAT_D77
Coding: 03141
Shop #: WSC 06435
VCID: 326D2F8AFE34409
No fault code found.
Address 15: Airbags Labels: 8L0-959-655-AI8.lbl
Part No: 8L0 959 655 J
Component: Airbag Front+Seite 3008
Coding: 01104
Shop #: WSC 06435
VCID: 458764565FBAC71
Address 17: Instruments Labels: 8L0-920-xxx-17.lbl
Part No: 8L0 920 980 B
Component: AB-KOMBIINSTR. VDO D11
Coding: 01444
Shop #: WSC 00000
Component: AUZ7Z0Y1524795
ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ AUZ7Z0Y1524795
1 Fault Found:
01177 - Engine Control Unit
Address 22: AWD Labels: 02D-900-554.lbl
Part No: 02D 900 554 B
Component: HALDEX LSC ECC 0006
VCID: 1F4BD63E9DA6FD1
1 Fault Found:
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 P
Component: CV-Pump, Alarm, RC D13
Coding: 15178
Shop #: WSC 06435
VCID: 428D7F4A4E94F09
2 Faults Found:
01134 - Alarm Horn (H12)
76-10 - Terminal 30 missing - Intermittent
77-10 - Internal Supply Voltage - Intermittent
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00001
Shop #: WSC 00000
VCID: E0C915C26058029
Address 55: Xenon Range Labels: 4B0-907-357-AUT.lbl
Part No: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00002
Shop #: WSC 06435
VCID: E5C704D67F7A671
there must be a protection fuse somewhere. you got a wiring diagram?
checked all fuses in car and under bonnet
Problem is now resolved
10
5K
725
7
2K
19
2K
14
