    May 2011
    22
    Question Grommet from bonnet to interior...
    Hi all,
    i have a a3 1996-2003 and i want to fit LEDs in my footwells tommorow. i know how to fit them all and do the wiring, just i have no idea where i can locate the grommet from under the bonnet to the interior as this is where i would like to run the wires for the power supply. any help will be great, pictures will be awesome too.
    Thanks in advance.
    Danman1's Avatar
    Thorough noob
    Sep 2011
    West Midlands
    338
    There are two grommets through the fire wall bulk head on the left and right side, take the scuttle panel off and you can see them.
    I think someone recently did a 'scuttle panel removal guide'....?
    Scuttle panel removal guide, with pics.
    May 2011
    22
    thanks for the mate, is there anyway i would be able to remove the wipers without the spindle tool? also, where abouts in the inside of the car do the ports come out, im guessing people use these ports for power cable for speakers etc too..
    cheers
    Danman1's Avatar
    Thorough noob
    Sep 2011
    West Midlands
    338
    You can remove it without the tool, its just harder due the wiper being at an angle and the wiper being under slight tension if you know what I mean.
    They are easy to get too because as you said people use them for running power cables to amps etc. You just need to get down in the arches and have a root around, I think they are behind carpet or sound deadening etc.
    Dan
    Lemon S3's Avatar
    Alex
    Sep 2009
    Bicknacre, Essex
    1,314
    Im sure theres one without having to take the scuttle off, its where i ran my boost gauge pipe and comes out behind the glove box. I can't remember exactly where as it's been a couple of years since i fitted my gauge, but Im sure you can get your hand behind the glove box and get to it (depending on the size of your arm/hand).
    1999 APY S3 Imola Yellow
    PS3: Broady_11
  1. steam from bonnet
    By bansheeboyo in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th July 2009, 10:43
  2. Wiper clearance from bonnet
    By steve184 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 18th April 2006, 08:10
  3. are a4 (b5) interiors compatible for swap from saloon to avant?
    By darby7 in forum General Technical / How To
    Last Post: 26th November 2005, 11:20
  4. Upgrading interior from cloth to leather
    By AndyMac in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th July 2005, 19:46
  5. wierd wine noise from under the bonnet
    By nervus in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th September 2004, 10:47
