Hi guys i ahve got a rattle from the rear end n/s and its puzleing me its not the heat sheild on the exhaust or the rear back box and i am getting to the end of the options with it. Thanks joe
My rear exhast braket broke of might be that,mayby the little clip that holds the handbrake cable,rear disc sheild,loose rear pad caliper sticking?,best to get a free exhaust check from say qwik-fit then just have a look underneath,might be simple.
funny you should say that i am getting a knock when i am putting my foot on the brakes from the same side i was goin to have a look today but the weather no chance
My rattling was the rear brake pads, hadn't been fitted properly with the shims, you'll ony notice them start to rattle though once they've worn down a fair bit. It can be quite common.
It was a horrendous noise on the outside, I though it was the exhaust.
