Chris NottAH Fabrications
Results 1 to 10 of 10
    Jun 2012
    14
    rear wheel bearing replacement a3 18t
    hi guys. new to the audi sene.. just gt a nice a3 mk1 {agu},, rear bearing has a wine lol .am nt tha familair with the a3 so any {how 2s} will be a big help!! thanks dave
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    You need a press weelo, best letting a pro do it.
    Jun 2012
    14
    can you get the complete hub with bearing? would ov thought it would ov been a lot less hassel lol
    Y83OLK's Avatar
    Hulk Smash!
    Sep 2009
    838
    If its a fwd you can indeed get a bearing/hub pre made combo.
    Quattro's are a bit more tricky.
    Assuming yours is a FWD model:
    Its straight forward. Remove wheel, brake calliper and carrier and disc.
    Undo the centre hub nut (30mm 12 point) replace in reverse order.
    Jun 2012
    14
    yes its fwd. thanks for tha pal
    Suck.Squeeze.Bang.Blow
    Jul 2011
    Madchester
    228
    Might be cheaper to get just the bearing matey and getting a friend that's either handy with the tools or is aa mechanic anyway and getting them to do it rather than forking out for a whole hub/bearing ore-pressed combo?
    Hope you get it sorted easy enough either way
    Dibdub1
    AVLO's Avatar
    Mar 2012
    Doncaster
    268
    hi mate bit of a silly question but did you no it was a wheel bearing gone by play in the wheel or just a whine? reason for asking is just i have a bad whining which sounds like a wheel bearing but none of the wheels seem to have any play.
    BRING ON THE WET WEATHER ​QUATTRO FTW
    Jul 2011
    Madchester
    228
    Your actual wheel won't have any play on one edge in and out as such if that makes sense, if it is a bearing you'll normally hear it start a deep grinding sound at about 30mph upwards as you gradually accelerate.
    Hope this helps mate!
    Jun 2012
    14
    seems to be a whine bud.. comes n goes lol..starting to gt a bit louder now tho {ant checkd wat wheel yet}
    Quote Originally Posted by AVLO View Post
    Jun 2012
    14
    sound bud am going gsf {lincoln} in mornin..as need a dipsick tube aswell lol
    Quote Originally Posted by Dibdub1 View Post
    Dibdub1
  1. A3 rear wheel bearing replacement queries...
    By richrich14 in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th October 2011, 21:40
  2. Rear Wheel Bearing replacement.
    By P Crr in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 19th February 2010, 18:22
  3. Replacing rear wheel bearing
    By Leon in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th March 2009, 14:47
  4. Rear Wheel Bearings on an 8L S3
    By jesters3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th October 2008, 18:48
  5. Front Passeneger wheel bearing replacement - Any tips or guides
    By technics100 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 29th September 2005, 18:48
