Chris NottVolks Autos
Results 1 to 20 of 20
    s3cya's Avatar
    Apr 2012
    Exeter/newton abbot DEVON
    101
    Unhappy Serious problem S3 is dead need help please!!
    Right good morning everyone well except me !!
    so i had my new s3 booked in at the local audi for the free health check when i went to collect these were the problems if anyone can help with parts or ideas or anything please do im in dyer need and really want this car to be spick and span
    • Front suspension arms/bushes (O/S/F ball joint worn
    • Steering area (Play in N/S steering Knuckle
    • Both Front Drive Shaft Boots
    • V-Belt Heavily Cracked
    • Rear Coil Springs Snapped
    If anyone can help please do
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    Hummm... over dramatised the thread title a little haven't we lol...
    Parts can be bought from GSF/Euro Carparts/Dealer/TPS... these are fairly normal things to wear out...
    The car won't be 'dead' as you have put it but the parts list alone will hit 100-150 quid depending and 'some' hours labour... the spring will be dealer only unless you can get one off a car being broken or a scrappy/eBay
    Not sure how you want use to help tbh...
    If you can't do it yourself then a decent local garage can do this cheaper than a dealer..
    <tuffty/>
    s3cya's Avatar
    Apr 2012
    101
    very over dramatised sorry lol just was gutted when audi tried saying over 4grand for everything fixed through them but now decided what im doing as the coil spring is snapped its time for coilovers and everything else is minor ill do next week, but does anyone know where im able to get a steering knuckle from?
    thegoal007's Avatar
    Another S3 owner....
    Apr 2008
    surrey
    729
    seriously over dramatised heading.
    definition of dead needs looking up....me thinks.
    Anyway, call me a sceptic, I just find Audi's free health check a bit on the questionable side....most times.
    When's your MOT? - most of these will be probably be pointed out as warnings or failures depending on how bad they are. rear springs will definite fail and need addressing. As Tufty mentions, regular wear stuff, rear broken springs definite common problem with the S3.
    02 plate - 2002 - 225bhp - S3 - Ming Blue - completely standard - nuff said, OK there's a centre armrest, sunroof, BOSE speakers & black leather recaros, oh and the non OE chrome pack !
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,584
    Quote Originally Posted by s3cya View Post
    FOUR GRAND!
    That's more than your car is worth right? lol Audi health checks = WIN(for Audi dealerships and a donkey customer who would pay such an amount!)
    Steering knuckle sounds like track rod end, which are like not expensive at all. I'd go to a VAG Indy and get a quote for that work, I'd be surprised if it can't be done for well under a grand including parts.
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    Steering knuckle? now you put near side in the original post so are you referring to the steering arm ball joint or the steering column itself? as its a common issue for the universal joints on the steering columns to get a bit of play which typically requires a new steering column to fix it... which is why I can see Audi would want to charge so much
    As thegoal007 has said, Audi will find fault in everything... new v belt is 15 quid, front suspension arm is a bit of a vague description fault wise to comment, drive shaft boots are around 15/20 each (fit genuine ones tbh) and a 1 to 1.5 hours to fit...
    I have a slight movement in the steering which I think is the universal joints but its never been picked up in an MOT so not done anything with it... you should be able to get something like this from GSF but may have to be a dealer part..
    <tuffty/>
    s3cya's Avatar
    Apr 2012
    101
    from the quotation sheet this is what audi have put
    Steering Area
    Description-Track CONTROL A it aslo says Play in N/S Inner steering knukle
    sportquattro's Avatar
    Sep 2009
    Ivybridge, United Kingdom
    741
    £4000 is taking the mickey big time. I'd expect that lot to be sorted by an independent Audi Specialist for £500 tops A lot of it you could do yourself with a little mechanical savvy or a helpfull mate with some.
    1999 Audi S3 Superchips remap, Forge 007p, Phatnoise, Black Diamond Discs & DS2500 pads, N249 Deleted, Badger 5 TIP, Poly dogbone bush, Bilstein B8's and Eibach Springs.
    1986 Audi Coupe Quattro 2.2 restoration project
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    Steering Area
    That sounds like the track rod arm.... they are about 15/20 ish quid from memory? relatively easy to change and not expensive... did they give a breakdown on price? labour/parts? 4k seems a rather arbitrary figure to me...
    <tuffty/>
    s3cya's Avatar
    Apr 2012
    101
    yep for the part it is 161 from audi but i have a part number which is
    V8N0407151D
    and total parts from audi on there (quotation for work) is £1554.90
    total labour £1589.25 + VAT £628.83
    and all this is with millitary discount
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,584
    V8N0407151D
    They are having a giraffe!
    vrbob's Avatar
    Jun 2007
    Southampton
    2,363
    Quote Originally Posted by jojo View Post
    The worrying thing is i wonder how many people actually pay them to do this work as they dont know any better and think Audi is helping them out!
    Although this site makes me spend money its defo saved me a fair few quid too
    Mods : Badger 5 Stg 2 Custom Map, FMIC, 3" DP & 200 Cell Cat, 007P, Jetex Filter & 80mm TIP & Heatshield, Complete LED Kit, Gen VW Aero Wipers, Full Powerflex Kit, R32 RARB, AP Shocks & Springs, 15mm Front & 20mm Rear Spacers, BB Uprated Actuator,
    <tuffty/>'s Avatar
    Badger 5 Edition
    Sep 2008
    Gloucestershire
    15,602
    V8N0407151D
    That PN (8N0407151D) is the whole lower arm... which is the normal trick audi use to replace just a bush...
    A bush is 5-10 quid and just needs pressing in... the arm would need to be undone at the ball joint anyway to do the CV boots... so not much more effort to remove completely and press in new bushes certainly not 161 + labour
    Not a difficult job tbh
    <tuffty/>
    May 2012
    Norfolk
    118
    With blatant rip of prices like that i think they should be named and shamed if you have the quote to scan in as black and white proof that may stop some other poor sod being ripped off
    voorhees's Avatar
    Dec 2005
    Leafy Warwickshire
    14,914
    Quote Originally Posted by marty.h View Post
    I don't think name and shame is a good thing,if the procedure in their book for this is to change the arm rather than just the bush then what else are they to do ?
    Go to an independent for the work
    s3cya's Avatar
    Apr 2012
    101
    thanks for all this help guys it was exeter audi which quoted this as i am freinds with the son of audi south west's MD i thought they may not try to rip me off but owell indy it is ive ordered coilies to sort the snapped coil spring i have a GATES cam belt kit on order for 86£ which is a bargain think audi were just trying to rip people off
    Aug 2010
    1,540
    why go to the dealer? would be my first question. find a trustworthy independant that speaks in black and white.
    i mean a "free car check"? if they dont find anything "wrong" with the cars they "check" how do they make money? think about it.
    get an independant to check out what theyve highlighted.
    Sep 2009
    741
    Exeter Audi well known for over inflated prices sadly, would never ever ever ever use them. If your Exeter way try the Audi VW Centre in Pennsylvania, very good idependant garage and from personal experience do a great job at a decent price, will allways tell you whats what and whats not.
    jojo's Avatar
    S3 Drift King!
    Sep 2003
    Solihull, Midlands
    25,584
    Quote Originally Posted by murran View Post
    That's the trick isn't it?, everyone likes freebies!
    s3cya's Avatar
    Apr 2012
    101
    Ive heard good things about these ppl Thankyou bud
  1. One big long lasting problem need help please?
    By madmark in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th February 2012, 20:29
  2. 'FIXED' running problems need help please
    By Daboyracer in forum A4/S4 forum(B5 Chassis)
    Last Post: 30th March 2010, 17:24
  3. Problem - Need Help please
    By Herby1 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th January 2007, 11:48
  4. Mis-sold my car? No of Owners - Need help please!
    By Mike_P in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd December 2005, 12:23
  5. Need help please lovely people
    By imported_Beanflick in forum In-Car Entertainment
    Last Post: 5th March 2005, 16:18
